Hitachi P50v701 ps quality
  • freakaftr8
    • Oct 2012
    • 3743
    Hey all I just picked up this hitachi p50v701 plasma. Known issue is turns on quick flash of the raster then shutdown with blue led flashing 3 times. Closer inspection shows 2 100v 3300uf caps domed in the vs output of the ps. Ok so research shows that this issue will eventually spike the upper and lower scan boards shorting an ic and wreak havoc on the ysus. I got lucky on this set cause the buffers are still testing ok. With both buffers disconnected set will stay on for about 2 minutes then shutdown with same 3 blink. My testing shows massive ripple in the vs line. You can actually see this on the screen with massive maldischarge pixel flash and vertical smearing of the osd before it cuts out.
    I have not run into another power supply using such high value caps like this. With the rest of the tv seeming like high quality boards and build why would they cheap out on the power supply and cut corners and not have more circuitry added in so they don't need 3300uf caps?
    Re: Hitachi P50v701 ps quality
    My guess is the caps were insufficient - potentially they just reached the end of their useful life.
    • freakaftr8
      • Oct 2012
      • 3743
      True. I've repaired many power supplies on the past but this supply seems rudimentary.
      • freakaftr8
        • Oct 2012
        • 3743
        Ok new caps in the power supply. Same problem. Power up and quick flash of maldischarge. Then powers off immediately and 3 flashes. Ysus board error.
        My question. I have had repaired buffer boards before but how do u test these buffer boards? I cannot visually see any burned ic's. and both upper and lower board when installed individually does the same thing. Although for like 5 seconds before when the lower board was on the set stayed on with a lit lower raster. Blank of course.
        Thanks guys
        • freakaftr8
          • Oct 2012
          • 3743
          Actually it was the buffer boards. I'm in the process of rebuilding them at the moment. Got the top one finished. Loos good just one chip bad there. The bottom on the other hand has four shorted chips. Fun fun. Still trying to work the bugs out of it.
          • Shane711
            • Dec 2014
            • 493
            How do you test the buffer boards without seeing a burnt IC? I tested for short to ground but I did not find any shorts. I am thinking I have a bad Y-SUS or PS.
            • Jaime Morillo
              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
              by Jaime Morillo
              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
              The TV was stuck on the logo and I couldn't access the update menu.
              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
              The image result was good, but the image is inverted.
              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
              08-18-2025, 11:38 AM
            • DXseekerMO
              Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
              by DXseekerMO
              Hello everyone!
              Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
              I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
              Yes
              0%
              1
              All backlight strips are the same quality
              0%
              1
              No
              0%
              0
              12-16-2021, 03:58 PM
            • wolf1976
              hitachi 50hk5600 problem with display
              by wolf1976
              hi
              i have the above tv and the display starts distorts the display at only in applications like you tube
              after and on the didital channels
              now without connect the antenna only the image of itsselfs tv i have the image i have in attach
              i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
              can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
              09-13-2025, 02:26 PM
            • massimomax
              Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
              by massimomax
              Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende piΓΉ,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
              spero che qualcuno puΓ² averlo per riprogrammare eprom. grazie
              Post in English !!!
              I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
              02-28-2025, 07:27 AM
            • gutkin
              HP 250 G8 Compal FPW50 LA-H325P
              by gutkin
              Hi colleagues.
              Here I am asking for help.
              πŸ†˜πŸ†˜πŸ†˜
              I've entered this HP and it won't turn on. I can't find a schematic or boardview.
              The first fault I found was a JW5069a IC (compatible with JW5068a). It had an internal fault, which was replaced, and now I have a stable 19V. When I press the power button, the LED appears, but it still consumes 500mAH.
              I continued taking measurements and found that the PUG8 IC is not receiving an EN on pin 2.
              PUG8:
              Pin 1 5V
              Pin 2 0V
              Pin 3 1.8V
              Pin 8 5V
              Pin 12 5V
              Pin 13 19V
              Pin 2 of...
              07-29-2025, 03:27 PM
