3100 receiver will not acquier signal
  • cheebster
    • May 2008
    • 374
    Re: 3100 receiver will not acquier signal
    jkeys.. hehe been a while yes. does the ird boot up (green led lighting up at least one quick second on bootup) ? any firmware on it ?
    • t.j.
      • Apr 2010
      • 383
      • canada
      is it a uni jtag? make sure cable in right slot! an make sure ya have it the right way, pogoed will take a couple of stabs at it!
      • davg
        • Sep 2008
        • 536
        Ya it worked back in the day (non buffered soldered) nothing has changed? It will not read now? 2700 no problem must be something to do with the 3100 Its been a long time loss my touch.
        • cheebster
          • May 2008
          • 374
          did you try the top jtag ?
          • t.j.
            • Apr 2010
            • 383
            • canada
            make sure no cold solders on the head of the jtag!
            • davg
              • Sep 2008
              • 536
              It is the top jtag and the solder is good. I seem to remember having a similar problem way back when that was an issue with the 3100 only and I can't remember what it was and what I had to do to overcome it.
              • t.j.
                • Apr 2010
                • 383
                • canada
                #27
                dont ground to ground pad, tuck under a screw, an try wall if jkey fubarren!
                • cheebster
                  • May 2008
                  • 374
                  #28
                  well if the cpu isnt detected, wall will not do much. what i did on some ird's that wouldnt be detected at all with jkeys is to pull the tsops and flash them externally
                  • cheebster
                    • May 2008
                    • 374
                    #29
                    Or just.. do the junkyard fix and stream 'it!!!
                    • davg
                      • Sep 2008
                      • 536
                      Can you point me to the steps to move my sc to another ird? I have changed the IRD # and boxkeys in the tsop (new ird) with flashedit and have flashed that using jkeys. Thats all I can remember from days gone!! by there must be something else I need to do? Do I need to flash the eeprom? If I am in the wrong fourm let me know
                      • t.j.
                        • Apr 2010
                        • 383
                        • canada
                        #31
                        just virginize eep! use jkeys to make you one!
                        • davg
                          • Sep 2008
                          • 536
                          can you explain and which one do I have to virginize
                          • t.j.
                            • Apr 2010
                            • 383
                            • canada
                            #33
                            load tsops in flash edit , got to save area! an will see save eep! just save a new one, make sure to enter build correctly an write that to ird!
                            • davg
                              • Sep 2008
                              • 536
                              Thanks t.j. gotya. I saw it after I was wondering why you said Jkeys
                              • t.j.
                                • Apr 2010
                                • 383
                                • canada
                                #35
                                meant to say flashedit~ lol , asleep at the wheel again>>>
                                • davg
                                  • Sep 2008
                                  • 536
                                  Not a problem got her done thanks for your help
                                  • road
                                    • Feb 2013
                                    • canada
                                    #37
                                    To fix acquire signal all you need is a heat gun.just take out board and heat chip up were the cable goes. Keep gun about 3 to 4 inches away. reason to reconnect soil
                                    ding.let cool then injoy after doing a few
                                    now
                                    • AstutePauciloquent
                                      Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                      by AstutePauciloquent
                                      Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                      I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                      11-23-2023, 11:02 PM
                                    • CDNBrewer
                                      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                      by CDNBrewer
                                      Hello Everyone,
                                      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                      Symptoms:
                                      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                      • I swapped the Left and Right surround
                                      08-05-2025, 09:29 PM
                                      HP 3100 807UE Specification for Upgrade or Repair
                                      This specification for the HP 3100 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 3100 boardview and 3100 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP 3100 is accurate, safe, error...
                                      09-12-2024, 03:28 PM
                                      DELL Chromebook 3100 Chromebook Specification for Upgrade or Repair
                                      This specification for the DELL Chromebook 3100 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3100 boardview and 3100 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Chromebook...
                                      09-07-2024, 02:20 AM
                                      09-07-2024, 02:00 AM
