3100 receiver will not acquier signal
  • davg
    • Sep 2008
    • 536
    My 3100 satellite receiver will not acquire satellite signal. It is intermittent but will not lock on. I tried my other receiver with the same connection and it works fine, so that rules out a bad cable. The symptoms is the same as a loose connection and it has to be in the receiver but I just can't find it. Any suggestions? I have had this unit unplugged for some time as I only use it at the cottage. There is no warranty as I own the unit. I have not called my service provider yet. Hope this is the right forum to post this.
    • Jul 2011
    • 6064
    Re: 3100 receiver will not acquier signal
    If I had this unit I would open it up and see if you see any caps that have pop there tops if not then ......>
    Also if you have a ESR cap tester I would check all of the caps in this unit
    • t.j.
      • Apr 2010
      • 383
      • canada
      all the 3100's i have opened up have Nichicon caps in them!
      plug in ird, with all connections, turn off using power button of ird! let sit over night! try again in morrow!
        • Jul 2011
        • 6064
        What dose this do for 3100 satellite receiver Please explain
        • t.j.
          • Apr 2010
          • 383
          • canada
          if software on the ird is way out of date , you will experience issues like davg is!
            • Jul 2011
            • 6064
            Thank for the info
            • davg
              • Sep 2008
              • 536
              Thanks t.j they are Nichicon caps. I will give your suggestion a try nothing to loose. I do have a deactivated 6100 here that will acquire the signal and give me the preview channel??
              • t.j.
                • Apr 2010
                • 383
                • canada
                after software updated, do a check switch menu~6~1~1
                if ird is dead. could always use a jtag an put the info needed on the 61 from the 31. ie: box keys an cam id!
                • davg
                  • Sep 2008
                  • 536
                  Thanks again t.j. just saying that the 6100 has been out of service for quite some time since bell replaced them last year,yet it will acquire signal? Got a feeling it is dead. Don't believe you can jtag a 6100?? I will check and see what bell will do for me.
                  • t.j.
                    • Apr 2010
                    • 383
                    • canada
                    your right 61 can not be jtagged! i got some 3100's here will test them to see if they work, no card for them though./ if yours is dead i send ya one of the ones i got! was just going to scalp them for caps! an other odds an sodds. an if need parts to build jtag if ya dont have one i can send ya! might have enough for a buffered tag!
                    • davg
                      • Sep 2008
                      • 536
                      Thanks t.j. no need for that was hoping for a simple fix. Oh will maybe I will upgrade to HD
                      • t.j.
                        • Apr 2010
                        • 383
                        • canada
                        i have a stack of 3100'S. but ya HD is way to go!
                        • t.j.
                          • Apr 2010
                          • 383
                          • canada
                          could also do hard reset!
                          With your remote control, press:
                          Menu>6>3>info>Right arrow(browse)>left arrow(theme),then the memory dump will pop up, When on the memory dump page simply hit the tv/video buton to corrupt the memory. unplug ird for 5 minutes. plug it back in~
                          • davg
                            • Sep 2008
                            • 536
                            So how would that work if the ird can;t get sat signal to download updates?
                            • cheebster
                              • May 2008
                              • 374
                              hehe. i've been messing for ird's for YEARS. if you do a hard reset like he said, and then do a check switch (menu-6-1-1) and it still doesn't find sat signal, make sure your cable is ok, like run a new cable to dish or something...
                              or try another receiver at the same location with the same cable. if 100% sure signal is ok, it's the tiny sat input chip at the coax input location (under that metal cage, you pop the cover there) that is disconnected from the main board. it's a small QFP maxim chip about 10X10MM square with pins all around.
                              that chip has a ground pad in the middle of the chip, you can't see that unless you remove the chip. you need to reflow that chip to resolder the ground pad under it...
                              if you have hot air (a hot air gun tool) you can use that, or a small blow torch if you have that. the trick is to be able to reflow the solder under the chip, you need a lot of heat, but you got to be careful not to kill the chip but applying too much heat. one thing you can use with a blowtorch to avoid burning the chip, is to use a 1 cent piece on the top of it, with a heavy nut about the size of the cent. then reflow.. the weight of the nut will apply enough pressure on the chip to press a bit on it then assure proper contact...
                              if you're using hot air, you heat untill solder reflows, then apply a bit of pressure using a screwdriver or anything metallic on the chip, then wait about 1-2 minutes with pressure applied for the solder to cool down.
                              trust me, ive done about 200 of these in the past with the sat signal problem. always been that chip !
                              sometimes by intermittent connection, tho, those chips can die.. but it doesnt happen that often.
                              • davg
                                • Sep 2008
                                • 536
                                Thanks cheebster Might give it a try just for the hell of it. The problem is not intermittent any more there is no signal strength at all now.
                                And doing a hard reset will sometimes fix this problem??? BTW trying another IRD on the same cable works fine.
                                • cheebster
                                  • May 2008
                                  • 374
                                  ah so you got signal. my bet on the maxim chip then !
                                  post back when u try it..
                                  a good way to check sat output is simple, use your multimeter on the coax (stick anything in the hole of the coax center pin that you can put your meter positive lead on) and negative on the coax ground, then you should get 13-18v depending on transponders odd/even.. if no 13-18v there, then maxim is the cause as far as my memory goes !
                                  yes ive seen a check switch fix this, but rarely !
                                  something simple ive been doing, take the back of a screwdriver handle and press fairly hard on the maxim chip while ird is running, u'll see sat signal come back when the ground pad is disconnected since you're reconnecting it with pressure..
                                  did that often just to check if it was really the bad connection, always worked
                                  • davg
                                    • Sep 2008
                                    • 536
                                    Thanks again cheebster I did check the center lead and ground and do get 13-18 volts as a mater of fact as the transponders change from negative to positive so does the voltage. I tried check switch an no go. I have not checked the solder but will. I tried some pressure on that chip but nothing.
                                    • cheebster
                                      • May 2008
                                      • 374
                                      reflow the chip with heat. you need quite a lot of CONSTANT pressure to get that ground pad to be connected a few seconds for the signal to lock
                                      • davg
                                        • Sep 2008
                                        • 536
                                        Thanks t.j I have a 3100 with a Jtag attached but Jkeys is not reading maybe you could give me a quick update on Jtagging the 3100. Its been quite a while?? Might be fun to try again.
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
                                          HP 3100 807UE Specification for Upgrade or Repair
                                          This specification for the HP 3100 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 3100 boardview and 3100 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP 3100 is accurate, safe, error...
                                          09-12-2024, 03:28 PM
                                          DELL Chromebook 3100 Chromebook Specification for Upgrade or Repair
                                          This specification for the DELL Chromebook 3100 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3100 boardview and 3100 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Chromebook...
                                          09-07-2024, 02:20 AM
