Vizio P42HDTV10A power issue
  • blee1099
    • Apr 2012
    • 7
    Got a Vizio P42HDTV10A that stumping me. Basically it has no vs or va voltages. It does have the 5v standby and the orange standby light. When its plugged in initially, it'll click a relay once. At that point there is no va or vs voltages. Unplugged the cables to the Y-sus and Z-sus with similar results no vs or va voltage. The SMPS has a auto/normal switch, if its in the auto mode, the panel does light up and produces voltages @ Y-sus & Z-sus. Thinking either its a main board issue or a control board but not sure if there's a way to check to see if its the main. Was hoping there was a way to force the tv to turn on like the Samsung tv's where you can jumper the logic board and short the pins on the smps's power on & ground pins..
    Re: Vizio P42HDTV10A power issue
    Check for VS-ON signal.
    Samsung, LG or Panasonic panel?
    • blee1099
      • Apr 2012
      • 7
      LG panel.
      VS-on I get 5V
        So is it not possible to use PSU in auto mode? I'm a little lost.
        • blee1099
          • Apr 2012
          • 7
          Yea basically in auto mode no inputs show up.. I'm thinking its the main board but I see no mention of the auto/normal switch in either a LG or Vizio service manuals.
            In auto mode does it power up right away when plugging in? Maybe the main board isn't expecting that.
            • blee1099
              • Apr 2012
              • 7
              Yea it brings the backlight up on the panel right away along with the y-sus, z-sus, etc. Just no on screen display or functions.
              • allsyst
                Hi.. did you ever find the answer to your tv prob? mine is having the same symptons.. just an oragne led unlesss i slide the switch
                ty
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • gurj1979
                  Motherboard issue - all voltages OK but no display
                  by gurj1979
                  I've got a couple of Intel and AMD boards which turns on fine, all voltages at all coils are present, but there is no display.
                  I guess this like Code 00 issue.
                  I've tried a couple of good CPU's and working Graphics Card.
                  PCH has been replaced too. On one Intel board I have even replaced the CPU Socket.
                  The CPU's don't get hot, but gets a bit warm.
                  All RAMs are good.
                  BIOS is good on all.
                  PSU is Antec 1000W and I use this for on more powerful boards and 2080Ti cards, so this isn't the issue.
                  What's the issue when motherboards have this issue ?
                  02-24-2023, 05:53 PM
                • EazyBone
                  Vizio P759-G1, Tcon issue?
                  by EazyBone
                  Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
                  Any help appreciated
                  https://youtu.be/tPeV2Q7TXIQ?feature=shared
                  03-22-2024, 03:25 PM
                • remmurdmd
                  Vizio E65-E1 strange image issue
                  by remmurdmd
                  Hi everyone. First new thread here. I picked up a TV on the side of the road. It appears to function correctly with the exception of an image issue I'm unable to describe. I've searched for “double picture” and “double image” all over the web and all I get is repair videos for when the picture is blurry and the connections are getting interference between the display panels and the t-con board. I believe this is a t-con board issue, but I haven't found anything telling me conclusively that this is where my issue is. I'd appreciate any assistance you can provide. I live a pretty busy life...
                  10-02-2022, 09:12 PM
                • derrickcaputo
                  Issue with 42 Vizio TV
                  by derrickcaputo
                  I have a 42" Vizio TV. I hooked my tablet to the HDMI inputs. Everything was fine until the screen went black and now the only input that works on the TV is coax. No hdmi, no component, no rca. I tried hooking up a laptop to the Hdmi port and the computer
                  detected the TV model but no image.
                  Is there anyone having the same issue? Did you find any solution?
                  08-20-2024, 12:21 AM
