Samsung HP S5053
  • shorteddiode
    • 221
    Samsung HP S5053
    It turns on for about three seconds then turns back off. The blue light in the front flashes three times every time it turns on. I unpluged all the connections to the power board except the main board and it still does it. The PS_ON is at 3.65 volts when iot turns on, stand by is 5 volts when on. I pulled the power board and found Q5801 bad (AV2 18N50) Mosfet. There are no bad caps on the power board. I checked them with an ESR meterI did not find a short to ground on the buffer boards when checking with an ohm meter. No dark spots anywhere on the board. Has anyone else had this trouble and is there anything else I should be checking on the power or main board. The power board is PSPF501A01A. I have to locate my camera to send pics
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • ohren
    Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
    by ohren
    I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
    I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
    The models launched in 2018 and 2019 respectively....
    09-08-2023, 05:24 PM
  • C152Heavy
    Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
    by C152Heavy
    Summary for TL-DR readers:
    • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
    • Have obtained Samsung schematic & service documents - Can upload if helpful.
    • Have read ALL applicable threads
    • C1818 and CP820 replaced as low hanging fruit
    • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
    • VCC pin (18) of PFC...
    01-11-2023, 02:53 PM
    09-07-2024, 05:50 AM
