sony Kdl 46s4100 46"
  • Rudy.ALvarez91586
    • Sep 2012
    • 22
    • California
    okay so i have the tv and i got the new main board the one with the av jacks put in brand new from partstore.com and now instead of having a steady green i have a 2 flash standy error code does this mean i got a bad main board or is it the power supply G board bad
    Re: sony Kdl 46s4100 46"
    Did the old main board work, if not, is the fault the same? Is the main board from the EXACT same TV - Sony, as well as Samsung TVs, are very fussy with this.
    • Rudy.ALvarez91586
      • Sep 2012
      • 22
      • California
      Yes the mainboard is the same as the other one i pulled out i followed the serial on the tv manual and i also i have the troubleshoot manual the old main board fault was no picture no sound i also took voltage readings on the tcon and found that i wasn't getting 15 v where i was suppose to either
        Here's the service manual for your TV:
        "The units in this manual DOES NOT contain a self-diagnostic function."
        Argh! So they do not specify what 2 blinks mean and simply say "change both." How helpful.
        • Rudy.ALvarez91586
          • Sep 2012
          • 22
          • California
          but on the manual i got it from you from another post found it reading through other peoples problems through the tv anyways i also don't voltage goin to the tcon board where it says i should have 15v or so
            That may simply be because it's not passing its self check and not leaving standby.
            • Rudy.ALvarez91586
              • Sep 2012
              • 22
              • California
              okay also i don't get a test screen or sony logo when i do power it on when i had the other motherboard that didn't give me the 2 blink just the solid green at this point i am going to have to change the G board to get rid of the 2 blink problem
              • Rudy.ALvarez91586
                • Sep 2012
                • 22
                • California
                is there a back light bulb that needs to be changed on this tv I don't really see anything i followed all the instructions is there something visual i can see that will tell me that the tv is bad other than capacitors
                • drpj23
                  • May 2012
                  • 528
                  2 blinks for an S2000 model is abnormal voltage D5V/A9V power voltage.
                  And for your visual question, no not really lol.
                  Other than visually blown components (like something literally blew up) (and caps) it is testing and deductive reasoning.
                  So G board could be your best bet.
                  And I do not think this set is known for bad bulbs.
                  • Rudy.ALvarez91586
                    • Sep 2012
                    • 22
                    • California
                    i don't even get the test screen or voltage on the balancer board at all where are these so called bulbs ????
                    • drpj23
                      • May 2012
                      • 528
                      Ok, for the MB that lets the set turn on to the green light, what are all the voltages (in respect to the legend) coming out of the power supply?
                      LCDs need a backlight in order for you to see the image. Behind the LCD there are CCFL tubes (in your case) which are the lamps or bulbs in this sense. These don't usually go bad or at least A LOT less often than the HV transformers for them.
                      • Rudy.ALvarez91586
                        • Sep 2012
                        • 22
                        • California
                        but if they are bad is it expensive to fix (CCFL tubes) would the tv be worth it to fix it
                        Last edited by Rudy.ALvarez91586; 10-07-2012, 12:08 AM. Reason: thought of something else to add
                        • drpj23
                          • May 2012
                          • 528
                          I replaced one in a sharp. It was $22 for one but why are you so strongly suspecting the bulbs?
                          As far as I know, we could just simply have a power supply issue.
                          • Rudy.ALvarez91586
                            • Sep 2012
                            • 22
                            • California
                            well i have a new Mother board and power supply on order i will see what happens
                            • Rudy.ALvarez91586
                              • Sep 2012
                              • 22
                              • California
                              well i changed the both the G board and the A board (the main board and the power board) fired up the tv and been working like a champ sorry it took long to reply on the post for the people looking at this i forgot my password to get in and i been to busy watching tv
                              • jb_Bak
                                by jb_Bak
                                CN6401
                                Pin 01 NC
                                Pin 02 NC
                                Pin 03 "BL_ON": 0V
                                Pin 04 "N/C"
                                Pin 05 "STBY 3.3V": 3.5V
                                Pin 06 "GND": N/C
                                Pin 07 "AC_OFF"...
                                09-27-2021, 04:52 PM
                              • Dani_2024
                                by Dani_2024
                                10-28-2024, 05:06 PM
                              • ygorsan
                                by ygorsan
                                🧩 Problem Summary:
                                • I
                                07-28-2025, 08:34 AM
                              • JDC
                                (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                by JDC
                                ONN 100012588
                                Issue: No Power, Then Rebooting After Main Board Change
                                Short answer: replace main board and power board
                                Technical answer: replace main board and Q306 & Q307 on power board.
                                Long answer:
                                TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                07-15-2022, 07:39 AM
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
