Philips 15CN4321 Vintage CRT TV
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    The owner of this old (1988) 15" TV tagged it as broken. He claimed that the TV worked but it took some time to turn on and synchronize.
    I plugged it in but it never turned on. So, I decided to open the case and check for bad caps, cold solder, burnt parts, dust etc.
    The original capacitors are a mix of Rubycon, Nichicon, Chemicon, Jamicon and Lelon.
    13 caps were found bad, none of them bulging. Some of them completely open, some had higher esr and lower capacity than normal and some had normal capacity but the esr was a bit higher than the maximum allowed according to the datasheets. All were replaced with Rubycon YXF, Chemicon KY and Nichicon HE, except for a 400V 22uF that was replaced with a HEC 105C.
    The TV didn't turn on. It was stuck on standby mode. What did the trick for me was to press the channel buttons repeatedly. I am impressed with the picture quality of the tube, even though it is 24 years old. The sound is great and there is even a bass setting There are also RCA audio/video in and out connectors!
    I am keeping it.
  • mitchw
    Vintage Philips 4BM2797 CRT BW monitor repair/tuneup
    by mitchw
    I have a Philips 4BM2797 black and white VGA CRT monitor that is very dim. If I put the brightness at medium (indent at the pot), the text is barely visible in a moderately lit room.
    I looked around for a service manual, but was unable to find one. Also there are no G2/Focus adjustments on flyback...
    There is a row of adjustment trimmers, but they aren't marked..
    Anyone has any info about it?
    Thanks...
    01-12-2024, 12:39 PM
  • DrewPhillips
    Capacitor Diarrhea - Nichicon PL Series
    by DrewPhillips
    Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
    The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
    03-02-2025, 10:18 PM
  • alro7779
    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
    by alro7779
    Hello, guys!
    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
    09-14-2025, 12:25 AM
  • nick3092
    Mid/late 80's Nichicon Yellow Caps
    by nick3092
    I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
    08-28-2022, 03:56 PM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
