SONY KDL-52S4100 t-con problems
  • Akito
    • Sep 2012
    Hello, first post here.
    Ok I have a SONY KDL-52S4100 that has sound when on, but no Picture. The back light comes on but no pic, I bought a e-bay t-con "used" and plugged it in with no fix, but if I wiggle it I can sometimes get it to pop up a picture for a few sec, and some times after It heat's up some it works fine, so I do believe I have a bad T-con but I read somewhere on some forum/board. that this model TV used two diff T-cons though its build lifetime, So a T-con from SN# say 1 to 5000 wont work in a 5001 to 9999 units, kinda thing.
    Re: SONY KDL-52S4100 t-con problems
    A lot of the T-cons you buy on ebay and other shops are pulls from cracked screen TVs, which mean they are untested. I would send the "new" T-con back it sounds like it has an intermittent contact which could have been worsened by an impact (such as the TV being dropped in shipping, hence the screen getting cracked and the boards harvested.)
    • Daren87
      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
      by Daren87
      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
      08-13-2023, 03:25 PM
    • thelankanguy
      Sony KD-55X9000F TCON Issue
      by thelankanguy
      The TV shows a black screen with no image.
      TCON ribbon connectors were disconnected individually for image and there was no half image even.
      Later both ribbons were disconnected and TCON voltages were tested.
      12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
      There is also a short to ground in this circled inductor.
      Is this a TCON issue or something else ?...
      12-13-2024, 12:27 AM
    • bbrain
      Sony KD-55AG9 TCON?
      by bbrain
      I have this problem with my Sony 55' AG9.
      It flashes 4x.
      I have found the service manual, and seems it is the TCON.
      Before I buy a TCON can someone check the vid?
      Thanks in advance!...
      09-19-2024, 10:50 AM
    • rimwall
      Sony KD-65x8500b - bad Tcon or panel?
      by rimwall
      Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
      a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
      b) the Tcon board is malfunctioning,...
      10-24-2023, 07:58 PM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
