50" Panasonic Plasma dead.
  • spidey12345
    • Sep 2013
    Re: 50" Panasonic Plasma dead.
    to get to the button boards so I have disasemble the whole back panel, or is there any easier way to get to the vol/channel/SD card ?
      These things are built like overbuilt tanks, I don't think so. The IR (remote) sensor should be separate from the buttons, you could unplug the buttons and try without them.
      • spidey12345
        • Sep 2013
        thanks, I will try to disconnect the buttons
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • cloo
          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
          by cloo
          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
          After doing a factory reset this problem was gone and the picture was back to...
          01-06-2025, 06:02 AM
        • Alicat
          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
          by Alicat
          Stopped by this site trying to fix my parents Panasonic Plasma TV.
          Model number is TH-50PZ85U
          Power comes on and the red power light stays on solid.
          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
          I also hear a few clicks.
          I also think my parents said there was a thunderstorm and the TV failed after that.
          Section 6 in the service manual talks about power and no screen,...
          10-30-2024, 10:09 AM
        • Eaglecrest
          Panasonic plasma color stripe
          by Eaglecrest
          I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
          11-05-2025, 06:16 PM
        • Lintesir
          Panasonic P42S30 Plasma - Pink sparkles
          by Lintesir
          My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
          There is about a 5cm high region at the top without any sparkles,...
          07-26-2024, 03:16 AM
