My VIZIO is flickering please help
    My VIZIO flickers every few seconds. Can someone help me properly diagnose the issue?
    http://youtu.be/rQ2NVcLzFhU -There is a close up video of the problem
    http://youtu.be/Nep9FmOG97I -Here is a view from further away
    Let me know what you think
    This TV is less than 2 years old
    Model number is E370VL
    Thank You
    Re: My VIZIO is flickering please help
    Try reseating the LVDS cable. It goes from the main board to t-con.
      Ok will do I will try that later tonight and let you know if that works. Thank You
        please note it seems to happen after TV has been on for about 10 minutes
          That could be a connector expanding and separating.
            [IMG=http://img546.*************/img546/9594/img1634hu.jpg][/IMG]
            Uploaded with *************
            Which one is the correct cable?
              Both of the white flat cables are the LVDS cable. From your picture it doesn't look like your tv has a tcon board.
                Ok I reseated them and the TCON board is on the top you cant see it from that angle. I will let you know what happens
                  Still not working, it takes like ten minutes of continuous running for it start flickering.
                  Any Ideas?
                    I've got an idea but i don't know if it'll work. If it's flickering after 10 minutes put a window fan behind the tv and see if it'll run longer. Something might be "heating" up causing the backlight to shutdown.
                      lol my ceiling fan is already cooling it off, but I think I narrowed it down to heat loosening a connection somewhere.
