SHARP LC-26SH12U service bulletin for fixing low sound problem
    Any one has any details on what is doen to fix the low sound level problem? Very common sound problem that was there from the factory.
    I cannot find what SHARP has doen to fix this problem. Firmware or hardware update? See attach PDF. Thanks.
    Re: SHARP LC-26SH12U service bulletin for fixing low sound problem
    Is it present on everything, not just the digital output? My guess would be configuration - possibly EEPROM (hardware) or firmware settings.
      Low speaker level (I look at the analog audio level feeding the Linear stereo audio power amp , they are very low), low Digital audio output also. So many people have complaint abOut this low sound level. I know I can add a sigle transistor preamp (per channel) to the input to the power amp IC to solve the problem, but if it can easily be done some otherway per SHARP then I will do it their way. I do have a feeling it is firm ware update. I cannot find any firmware update at ELEKTROTANYA.
      • crashp3
        • Mar 2011
        • 81
        Bud:
        I sent the service manual information to tom66 - there were (2) addendums to the service manaul that were created just after the TSB information you posted above.
        In the addendums, it states there were (2) part changes to the board:
        IC101 - OEC6088A (looks like a new mainbord... shared with Sansui
        IC2407 - HY27US08281A-TPCB ( NAND memory )
        The original parts (first service manual) list the same location and actually the same part information/description. Assuming this is a firmware update (especially since NAND flash indicated a change), unfortunately the Sharp service site and consumer site have no firmware updates available.
          Does the issue also affect the 32" or above models? Maybe firmware is shared...
            Thanks crashp3 for the info. I will add my own transistor preamp instead for the power amp section.
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
            • Christos Tsiligiannis
              Marian Trace Alpha sound card repair help
              by Christos Tsiligiannis
              Hello to the forum.
              My name is Christos, I am new to the forum here and i am posting from Greece.
              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
              So i tried asking for a schematic from the company and they would not give me one. Instead they...
              11-18-2024, 05:26 AM
              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:30 PM
              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
