Panasonic #Th42ph9uk plasma.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    I am looking for a service manual for a Panasonic plasma Th42ph9uk.
    Can anyone help please?
    Re: Panasonic #Th42ph9uk plasma.
    Try this http://www.tgohome.com/ServiceManual...&Search=Submit
    Give it a few minutes to upload if it doesn't yet work.
    • killian6pk
      • Apr 2010
      • 502
      Try www.tgohome.com/servicemanuals
      If not there then try www.elektrotanya.com
      Have you ever stopped to think and then forget to start thinking again?
      As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
      • SEAWOLF
        • Nov 2011
        • 177
        Thanks for the manual tom66.
        • cloo
          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
          by cloo
          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
          After doing a factory reset this problem was gone and the picture was back to...
          01-06-2025, 06:02 AM
        • Eaglecrest
          Panasonic plasma color stripe
          by Eaglecrest
          I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
          11-05-2025, 06:16 PM
        • badcappo
          Dead Panasonic Viera TX-P65STW50 Plasma TV
          by badcappo
          Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
          Diode type G972s6 - D101 with a short
          Mosfet 06N90E - Q301 shorted
          Fuse T5AH 250V - F103 blown
          Diode D301 shorted
          Relay DG1U-17VDC II - RL001 blown
          I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
          11-24-2024, 11:27 AM
        • SACR
          Panasonic Plasma TH-P42X28K A-Board @ Mainboard Schematic needed
          by SACR
          I need Schematic A-Board @ Mainboard for Panasonic Plasma TH-P42X28K. Code : TNPH0842. I want to replace 1 MLCC but I don't know values (capacitance & voltage) & codes. Can someone help me? Thank you...
          11-20-2023, 11:53 PM
        • renech
          panasonic TH-42PC77U plasma television half screen problem
          by renech
          hello,
          I hope someone on this forum can assist me.
          I have a panasonic TH-42PC77U plasma television.
          the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
          i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
          I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
          I have read some posts that suggest the problem is related to the boards on the left...
          12-12-2022, 06:53 PM
