Acoustic Solutions LCD42761F1080P - No picture, working sound, backlight okay
  • garvint
    • Aug 2012
    • united kingdom
    Have a TV on my bench:
    - No picture - but backlight works (i.e. screen has a slight glow and the holes in the rear of the set are lit up white)
    - Sound works fine
    - TV appears to respond to commands e.g. changing source, turning on/off and volume control.
    I have taken back panel off and seen in the center a yellow motherboard (printed on it 17PW16-2) where power connects to it. The internal fuse is fine
    Some of the caps look like they have a white glue on them. Is this a leak from overheating?
    Should I just replace this board?
    Photos enclosed.
    Reply asap please!!
  • truep
    • Aug 2010
    • 373
    Re: Acoustic Solutions LCD42761F1080P - No picture, working sound, backlight okay
    The white stuff is just glue, usually no problem. your problem is most likely the tcon board under the metal shield at the top of your picture.
    • garvint
      • Aug 2012
      • united kingdom
      Thanks I have ordered new t con board and will install in.
      • garvint
        • Aug 2012
        • united kingdom
        I have changed the changed Tcon board as you mentioned above.
        However the problem doesn't seem to be that, I am not sure what I can do here, what else could this be?
          It could have been ruled out if you tested it first, we could have instructed you, to save you buying an expensive board. Do you have a digital multimeter?
          • marty_cam
            • May 2014
            • 19
            • Ireland
            Hi. I have similar problem with this Acoustic Solutions model.
            1., It completely died (no power or lights at) ... I replaced the PSU.
            2. It worked ok for a day, then failed to switch on next day, although on inspection there was sound but no picture.
            3. I replaced the Inverter board with a working replacement (I hope) it immediately goes to standby after trying to switch on (brief screen light up, then off)
            4. When I put the original Inverter board back in I have sound and no picture.... Although, when I tweak with the PSU flex cable which seems to feed the inverter board I can get the lamp to come on.... (maybe one time outta ten)
            In a nutshell, I'm completely lost here and was wondering if anyone has had similar problem with this or other model.....
            Any advice/info appreciated.
            • truep
              • Aug 2010
              • 373
              You may have bad solder joints at the connector. I have found a couple of sets with this problem.
              • marty_cam
                • May 2014
                • 19
                • Ireland
                Many thanks truep.... afaik... already tried many solder points, enough to make me see double...
                I know there is something i'm overlooking... I just don't wanna start chasing my tail :-(
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • LEECH666
                  Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                  by LEECH666
                  Good day ladies and gentleman!
                  I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                  This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                  I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                  01-19-2024, 05:46 PM
                • Christos Tsiligiannis
                  Marian Trace Alpha sound card repair help
                  by Christos Tsiligiannis
                  Hello to the forum.
                  My name is Christos, I am new to the forum here and i am posting from Greece.
                  So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                  To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                  So i tried asking for a schematic from the company and they would not give me one. Instead they...
                  11-18-2024, 05:26 AM
                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                  This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 02:30 PM
                  HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
