LG 50PC3D shuts off... bad caps?
    Re: LG 50PC3D shuts off... bad caps?
    Originally posted by akk944
    Hdmi clicks right off as well... coax stays on for a bit then does the same...
    Have you found the White Wash option yet?
    Look under MENU -> OPTION -> ISM METHOD -> WHITE WASH
    • akk944
      • Aug 2012
      • 60
      Oh its going to be in there. I thought i checked but didnt see it. Ill give it a try. What should i be looking for or doing once in that mode. Let me know. Thanks!
        If it shuts off real quick when you turn that on, then somehow the PSU is incapable of supplying all the power, or something is overheating. Possibly a cold solder joint somewhere.
        • akk944
          • Aug 2012
          • 60
          Alright it shut off real quick.. so it's something with the PSU for sure?
            It certainly sounds like it. With your meter, can you check the high voltage Vs (should be around 190V when running.) If it starts falling THEN the TV clicks off (you should hear a relay click or two) it sounds like a cold joint or controller shut down to me.
            • akk944
              • Aug 2012
              • 60
              Sure, where exactly should I be sticking the meter? Thanks.
                On the thick multi-way power connector which goes to either sustain board - the boards on the left and right of the TV. There should be a pin marked Vs. Post a pic if unsure.
                • akk944
                  • Aug 2012
                  • 60
                  Oh okay I'll take a look and post back on Thursday. I am away till then. Lets hope that's the problem? or the fix is hard for it? Let me know. Thanks!
                    It's a very difficult problem - not one I'm well experienced with. I hope you can fix it.
                    • akk944
                      • Aug 2012
                      • 60
                      Uh oh.. that doesn't sound too promising haha. But, would replacing the whole PSU board do the trick though? Thanks
                        Possibly. I couldn't guarantee it. I do have a spare main board for the 42PC1D; that's probably the only other cause, and likely to be compatible.
                        • akk944
                          • Aug 2012
                          • 60
                          Alright sounds good.. I'll test out what you told me to on Thursday and hope I can get this thing working by the weekend. Will keep you posted. Thanks!
                          • akk944
                            • Aug 2012
                            • 60
                            Hey guys, I swapped out the power board with another one and that fixed the problem. I prefer not to use it since it was pretty expensive, but i will try and run the tests you mentioned. What's the fix for it though? Would it be worth or possible to fix the old board or should i not even bother.
                              Possibly a cold solder joint or intermittent component - could be tricky. Glad you found the fix...
                                by momaka
                                03-12-2025, 03:42 PM
                              • eryjus
                                by eryjus
                                05-10-2023, 11:21 AM
                              • Paxman_Swede
                                by Paxman_Swede
                                Hello!
                                01-14-2025, 09:51 AM
                              • captain150
                                by captain150
                                03-16-2025, 07:34 PM
                              • Foetuss
                                Gigabyte GA-6OXT :: caps question
                                by Foetuss
                                Good evening
                                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                But I was also suprised about the bigger boys, which are 330µF 25V.
                                Could it be they used 25V caps because they were cheaper / available at that time?...
                                02-11-2025, 12:22 PM
