Emerson LC401EM2F
  • retiredcaps
    replied
    Re: Emerson LC401EM2F
    Originally posted by lilmonk3
    Readings in diode mode with D606 Removed
    D606 OL .663
    D1215 .027 .027
    D1603 .125 .142
    D1401 .665 other way Climbs to .980 then OL
    D1215 and D1603 are both shorted in circuit. Remove both and retest out of circuit.
    D606 is good out of circuit. Leave it out of circuit for now.
  • lilmonk3
    replied
    D606 OL .663
    D1215 .027 .027
    D1603 .125 .142
  • retiredcaps
    replied
    Ok will do .. I have been using the diode setting..
    Then report your readings all diodes. Your results in post#8 are vague. "large #s' mean nothing.
  • lilmonk3
    replied
  • retiredcaps
    replied
    D606 Reading 000 both directions
    Remove D606 and retest. I normally use diode test function on the multimeter.
  • lilmonk3
    replied
    Ok I have some time to mess with this.. Here are a few results from some diodes that I have tested
    D1215 Is reading large # s in both directions
    D1401 " "
    D1603 " "
  • lilmonk3
    replied
    Same model here and same problem... Blows the fuse as soon as its plugged in. Been busy with back to school stuff so I have not had time to mess with it.. But, I have unhooked all boards.. And one by one I hooked them back up..
    Grey flat power cable going from PS to Main, fuse fine but no life on standby lights or power.Next was Flat white slip in ribbon cable going from PS to main
    and thats when the fuse blows..Hopefully I can find time soon to get back to my TV stuff.
  • rn74
    replied
    Thanks. I tried them all and no joy.
  • killian6pk
    replied
    Check tom's free site under each of those and see if there is a service manual. Most of the time they will have a flow chart that helps to run down problems.
    http://www.tgohome.com/ServiceManuals
  • rn74
    replied
    Thanks for the replies. I did check that link and that very diode appears to be faulty on mine as well. I found several others near that relay that are also bad. It may have been hit with a power surge. It was turned off and nobody was present, but there were storms in the area.
    I'll post some pictures as soon as I'm able - likely first thing in the morning.
    Looks like, per shopjimmy.com, that this model's power board is also used in:
    MAGNAVOX 40MF401B/F7
    PHILIPS / FUNAI CLC401EM2F
    SYLVANIA LC401EM2
    SYLVANIA LC401EM2F
    SYLVANIA LC401SS2
    So I've started looking for information on those as well, but no luck yet. Thanks again!
  • killian6pk
    replied
    Hello and welcome. I tried to find a free service manual for your tv, but could not. This is a link to a site that sells the service manuals. Tom66 has a free site for manuals but could not find one there either. http://www.service-manual.net/ashop/...tpage=4&shop=1
    You need to post pictures using the section under go advanced below the quick reply. Take one picture of back of tv after removing the back cover. Then one picture of the back and front of each of the power and main boards. Resolution no more that 2000 x 2000. We need to be able to read the printing on the boards. No flash just well lit.
  • selldoor
    replied
    Did anything accompany the not working? Bang Flash?
    Was it subjected to any powersurge.
    One way instead of testing all components is to rig a lightbulb in place of the fuse - see here
    http://antiqueradio.org/dimbulb.htm
    Dont think we fixed it but this will give you some ideas
    https://www.badcaps.net/forum/showth...M2F#post250318
    You will need to post pictures of YOUR boards.
  • rn74
    started a topic Emerson LC401EM2F
    Emerson LC401EM2F
    Hello. I have an Emerson 40" LCD TV that stopped working. I removed the back panel and noticed the 8A 250V fuse near the AC input was open. I'm pretty familiar with working on computers (replacing caps, power jacks, etc.) but I know little about TVs.
    I can simply replace the fuse, but I'd rather check around and make sure everything is good before I put power to it again. All the caps look fine, no signs of damage visually.
    I saw a Youtube video where someone had the same problem. He determined, without saying exactly how, it was on the AC side. Then he determined he had two bad diodes. Again, he didn't say how. Can someone walk me through what I should test?
    Thanks!
  • corrize
    A funny fuse story – Lumix LX100 II
    by corrize
    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
    10-19-2023, 09:58 AM
    Surface Mount Fuses Fundamentals Datasheet
    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
    10-07-2024, 06:07 AM
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    by sam_sam_sam
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-12-2024, 02:30 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
