Philips 52PFL5704D/F7 Sound and Backlight, No Video.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Philips 52PFL5704D/F7 Sound and Backlight, No Video.
    Sorry about that, I have just realized what you were referring to.
      Great. Now I know. Do you see CN2 with lots of little silver dots next to it, below "RUNTK"? Connect the ground probe of your scope to the brown copper exposed to the LEFT of these. Then carefully touch and hot the probe on the dot. Press AUTO on the scope (cheating, but it will work for now.) Do you see anything? If so, the main board is probably sending data but the T-con isn't listening.
      If you don't get anything, try the a few other dots until you get something. But if you still don't get anything, the main board is faulty.
      • kevinm34232
        • May 2012
        • 1884
        Also you have 12v on at the fuse but no voltage at IC201 right? So it would appear that something on the T-Con is shorted..
        • tibimakai
          • Jan 2012
          • 3680
          Not shorted, but bad. What that could be, that is the question.
          • tibimakai
            • Jan 2012
            • 3680
            I don't know Tom, what is going on, but I can't see any sinuses or square waives. There is something going on, but it's all concentrated along the horizontal line. No matter what kind of adjustment I'm doing on the scope, can't make that signal to show bigger.
            The voltage measured is 14.4V-15.2V on the scope.
              That would mean the main board isn't sending a signal some how. You pressed AUTO when you probe one of them?
              • tibimakai
                • Jan 2012
                • 3680
                Yes and then bumped up the voltage to 20V and I was adjusting the time from min to max.
                • kevinm34232
                  • May 2012
                  • 1884
                  Sorry I don't have a scope to compare readings for you...
                    You want to lower it to possibly as little as 100mV/div and 100ms/div but you still see nothing? Scope is definitely RUNNING, not waiting for trigger?
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Not sure to tell you the truth.
                      Today I have measured those taps with the DMM and I was getting only 1.1V-1.2V, then I realized that I have a switch on the probe(1x, 10x) and most likely I was on the 10x setting.
                      Could you please tell me how would you set yours(our scopes are probaly identical scopes) step by step as you turn it on?
                        Set it to 1X and go to the Ch1 menu and select 1X too. Take a screenshot of your scope image - try STORAGE->BITMAP and save to USB.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I have measured the first pad from the side of the board, but it comes out a .ref file.
                          I can't view it or attach it here.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            I have reconnected the panel ribbons and the TV started right up.
                            Explain this one.
                            I have noticed that all the processors on the T-con are running very hot. I have reinstalled the shield to take over from that heat, but it doesn't seem enough.
                            Now I have put a fan on top of it and let it run and see if it will fail this way.
                            I took some pictures with the scope screen. I will post it in a bit.
                            The VDO(if it's a VDO) measures 3.2V/0.003V/2.5V now when is working.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Here are the pictures when it wasn't working(no video signal either).
                              • kevinm34232
                                • May 2012
                                • 1884
                                Yes mine run hot too, I also noticed that too and put on the shield just while I was testing the boards. It would probably be a good idea to put some good aluminum heat sinks where the sponges are.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I have left it overnight(9-00PM-6:00AM) with a fan pointed upwards at the TV(TV vertically with removed back cover and the fan-Tornado- pointed up) and in the morning it was still running.
                                  I will install some heatsink and see how it will work. I think that I have some PC CPU heatsink around the house and see what happens with that.
                                  The mainboard processor it gets pretty hot too.
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    Do you think then the ribbons weren't fully seated before?
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Initially when I've got the TV were crocked and not inserted all the way in.
                                      After re-seating them correctly, the TV fired right up and I thought that I have fixed the TV.
                                      After a couple of hours of run time, I have turned it off(wanted to do a firmware upgrade) and after I have turned it on, the video signal it was gone. For a couple of days I was doing some measurements and the ribbon cables were removed from the T-con. After reinserting them last night, the TV fired back up again. It seems, that every time I'm reinstalling the panel ribbon cables the TV turns on again.
                                      Something weird it's going on here.
                                        Try cleaning the cables with a little isopropyl alcohol or contact cleaner.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          I have done that already. Thanks for the advice though.
                                          I have a feeling that it's heat related.
                                          • Max514
                                            Samsung UN55H8000 sound but no backlight no video
                                            by Max514
                                            Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                            The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                            I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                            • Unplugging the main board cable at the power supply >>> backlights came on.
                                            • BLU_ON signal from the
                                            04-14-2022, 10:34 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • bohaboha
                                            PHILIPS 58PUS7555/12 Backlight Sound ON Only Halv Screen
                                            by bohaboha
                                            when i power on the TV is black ,Do I remove the right or the left ribbon I get respectively the right or the left half screen working
                                            Do I disconnect the plug from the power supply, no backlight
                                            Thought the backlight would light up when you remove the plug from the power supply but no
                                            What could be wrong if both halves work separately?​...
                                            03-07-2025, 09:45 AM
                                          • gl4709
                                            Samsung un55cu7000d with backlight and sound No Video / Picture
                                            by gl4709
                                            I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                                            01-23-2025, 06:21 PM
