Zenith z60pv220 plasma won't power on
  • Getmoney2957
    • Aug 2012
    • Usa
    When I first plug it in it clicks. The light will be red wich I assume is standby. When I push power it clicks again then the light blinks off then back on then fades out. No picture no glow in the screen no sound I replaced the power supply board with no luck. Dont see any buldging compacitors.. Help please!?!?!? I have no electronic experience so try to be as detailed as possible.
  • cadiman
    • Mar 2010
    • 397
    Re: Zenith z60pv220 plasma won't power on
    That is most likely an L/G and you will have a failed y board (left of the tv looking at the back of it or z board. (right side)
    I would not be poking around the back of a plasma tv with no experience. Not without reading here a bit more.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Cooperr
      Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
      by Cooperr
      I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
      The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
      10-21-2025, 01:11 PM
      03-31-2024, 02:12 PM
