What do you guys think of this one?
  • Paul678
    • Nov 2011
    • 402
    This guy has a HP 42" Plazma TV
    PL4260N
    Model # CPTOH-0602
    Only the left half of the screen works. When on you can see the words "no signal" scroll around the left side then dissapear moving to the right.
    He has a brand new remote and powercord with it.
    According to this:
    http://www.justanswer.com/tv-repair/...lack-left.html
    It may be this main logic board:
    http://www.shopjimmy.com/lg-6871qch977b-ctrl-board.htm
    Which I also found on Ebay for $40:
    http://www.ebay.com/sch/i.html?_trks...item43b18d1f2f
    What do you guys think? How much should I offer him
    for it?
    It looks fixable......
    Re: What do you guys think of this one?
    Possibly bad panel COF failure, unrepairable. It occurred to one user on this forum on an LG plasma. Would generally avoid.
    • Paul678
      • Nov 2011
      • 402
      Thanks for your response, Tom.
      What does COF stand for?
      You are pretty certain that website is wrong about the main logic
      board being the culprit?
      Assuming you are right, and it's unrepairable, what would you
      offer him just to sell the parts on Ebay?
        Chip On Flex. Individual X driver ICs mounted on the plasma panel's flex itself. Unreplaceable...
        No, it could still be the main board, but such a failure is rare.
        $10... but I wouldn't normally bother.
        • Paul678
          • Nov 2011
          • 402
          Ok, so the COF circuits typical fail with all of one side
          of the screen going blank?
          What % of the screen does each X drive IC control?
          • scokljat
            • May 2012
            • 275
            • Croatia
            I would suspect right X board or control board. Maybe even just flat cable from ctrl board to right X board.
            As I understand picture is missing on whole right part of the screen. If it's COF than it should be all COF's for right part of the screen, not just one. If it's just one or two non working bars it could be a COF. I believe it's quite rare that all COF's from one side corrupt at once...
            Cheers!
            Suad
              It sounds quite rare but a control failure apparently causes all COFs on one side to fail. So it's a combined failure of control board and COF, although the control board failure may be very temporary.
                Here's the post
                https://www.badcaps.net/forum/showth...&highlight=COF
                • scokljat
                  • May 2012
                  • 275
                  • Croatia
                  Than it should be some visible burns and damage on the COF flex cables and components on it. There are some SMD resistors on COF's that actually can be replaced...
                  Paul678, could you remove x board on that part of the screen. It could be also needed to remove large long aluminium heatsink so you have to remove both x boards and heatsink to free all COF's. Then inspect closely all parts and lines on non working side COF's. There should be some visible damage. Use a spyglass... take some closeup pics.
                  Cheers!
                  Suad
                  • Paul678
                    • Nov 2011
                    • 402
                    Cheers!
                    Suad
                    Well, I have to buy it first...haha.
                    I asked the guy how much he wanted for it, and haven't gotten
                    a reply yet.
                    Yes, you touched on what I was getting at, that it would seem
                    unlikely for all the COFs on only one side to fail at the same time.
                    However, Tom may be correct that another part of the circuit
                    can actually cause this.
                    I suppose I will consider buying it for $10 or less, and then
                    see what I can find......expecting it to be only good for parts....
                    ....but maybe I'll get lucky....
                      There are resistors on the flex, but only on the older LG plasmas in my experience; the newer ones have all the resistors on the X boards, and they are per channel.
                      • scokljat
                        • May 2012
                        • 275
                        • Croatia
                        I suppose I will consider buying it for $10 or less, and then see what I can find......expecting it to be only good for parts....
                        Well, if panel is bad, but all (or most) other boards OK, I call it good bargain even for 40-50$. Y-SUS, Z-SUS, ctrl board, Y buffers, main video board and PSU!! Look at the prices on ebay. Selling it board by board at 50% lower prices than ebay it's 150-200$ for all parts. If TV has picture (even half of it), most crucial boards and maybe even all are OK. I could bet all boards except ctrl and one x board are OK ;-)
                        Cheers!
                        Suad
                        • Paul678
                          • Nov 2011
                          • 402
                          Cheers!
                          Suad
                          Very true. I get over not being able to fix a
                          TV I spent $10 on, when I make $60 on the power supply
                          alone.
                          Then often the other boards also sell, but at the slower
                          rate. But it's quite good to have a big selection of
                          TV parts on Ebay......
                          Especially when you get the TV for $5, or very often
                          for free!
                          • zmeutul
                            hi guys i need bios for 6-77-NP50PNJY-D02B-3C
                            by zmeutul
                            hey guys I need a bios for 6-77-NP50PNJY-D02B-3C.With the current one, the laptop does not start. I am also attaching the original bios. Thank you!...
                            09-26-2024, 01:55 PM
                          • fluffyhat
                            Help, guys. Lenovo ThinkPad T14 Gen 1 screen artifacting, RAM or GPU? video
                            by fluffyhat
                            Hello, I just replaced a motherboard on a T14 Gen 1 (20S0-0030US), with a 'working' T14 Gen 1 (20S0-005RUS). The screen glitches (see attachment) randomly or under minimal load. I tried running a memtest86 but as you can see it just glitches out before anything can happen. And the only way I can boot the laptop back up is by removing the CMOS battery for a while.
                            Any ideas? I'm seeing that you can bypass the on board memory by messing with some resistors, but i'd like to know what the issue seems to be first before doing any of that....
                            11-22-2025, 10:26 PM
                          • vikivng
                            guys..i need help with this lcd display used on ebikes pls.
                            by vikivng
                            This is an lcd display used on ebikes.
                            long story short, there was condensation inside the unit.
                            I opened it and thoroughly cleaned the pcb with isopryl.
                            The board had no visible corosion.
                            It powered on fine and was tested for an hour or so.
                            However when connected to the bike,,it did not power on at all.
                            I took it home and reopened it to take a look. There are no shorts based on MY testing.
                            However,,when I probe the transistor and the mosfet gate in diode mode or contuinity mode, (one probe on transistor collector and one probe on mosfet gate}the unit...
                            09-16-2025, 12:56 PM
                          • oneduane
                            Samsung Plazma Blues Model PN59D550C1F
                            by oneduane
                            I Am Looking For Some Direction, Or Suggestions On Where I Should Focus My Attention. I Have A 59 Inch Samsung Plazma Tv. The Tv Was Working Decently, Maybe Once In A Blue Moon, I Had To Unplug And Plug It Back In, As The Tv Would Just Shut Down And The Standby LED Light Would Come On And Stay On. If You Tried To Turn The Set Back On, The LED Standby Light Would Blink Rapidly Until You Released The Remote Button. Too Fast For Flash Codes. Once Plugged Back In, The Set Would Work Fine, Sometimes For Months. I Took The Back Off Of It, As The Was Some Distorted Pixels On The Right Side About 1/2...
                            09-07-2023, 08:17 PM
                          • kingthink
                            Hi guys, can anyone tell me how to extract the main BIOS file with this ASUS BIOS upg
                            by kingthink
                            Hi guys, can anyone tell me how to extract the main BIOS file for this ASUS official BIOS, attach the original BIOS and the official downloaded BIOS upgrade package....
                            07-04-2023, 11:00 PM
