Samsung PN50C6500 No picture, sound good
  • dougw03
    • Jul 2012
    • 12
    I did some research and stumbled upon these forums. I have a Samsung Pn50C6500 and it recently randomly shut off and will turn back on but have no picture. Sound is fine, just no picture. I think it may be the XSUS YSUS or main logic board. As far as inside the panel, all of the caps look okay and the main logic board LED's are still blinking. So how can I determine which board is the problem? I would rather not buy all three boards if possible. I have a multimeter available, but no oscope or any other equipment for diagnostics. Any help would be appreciated. Thanks!
    Re: Samsung PN50C6500 No picture, sound good
    If turned on in a dark room do you see any glow from the screen at all?
    Try unplugging the X sus and see if it turns on. It should turn on with a dim picture if this board is shorted.
    • dougw03
      • Jul 2012
      • 12
      It is completely dark with no glow. I unplugged both the power and ribbon cables (I couldn't disconnect the buffer without removing the boards) from the XSUS and there was a flash of grey/black when I turned the TV on then the screen went black again. I also could hear the buzzing that I normally hear from the TV. I proceeded to unplug the TV then reattach the XSUS and saw a large spark at the XSUS board power connector. I realize I probably should have waited for the caps to discharge. Is this enough evidence to assume the XSUS is the problem?
        Do you get a flash with the X SUS connected?
        • dougw03
          • Jul 2012
          • 12
          No I do not.
            Usually a dud X sus would give a dim picture... I would say Y sus first.
            • dougw03
              • Jul 2012
              • 12
              Ok I'll go for the YSUS. Is there anything I can do with an oscope or DMM that might help me know for sure? Thanks!
                You have a scope? You didn't mention this .
                You can check the Y sus and X sus waveforms, there's usually a test point.
                Use a 10X probe. The outputs from Y sus peak to 380V sometimes. Test relative to metal case.
                • dougw03
                  • Jul 2012
                  • 12
                  Ok so I am getting a 10X probe on monday. I've never worked with such high voltages and an oscope, are there safety precautions I need to take before I measure? In the meantime, here are the test points I found
                  http://www.flickr.com/photos/27836521@N07/7626108936/
                  http://www.flickr.com/photos/27836521@N07/7626103082/
                  Should I be looking for a particular waveform? Thanks
                    The precautions are:
                    - Use a fixed 10X probe
                    - Use a 10X probe which can withstand 400V
                    You're looking for the waveform which goes to the buffer boards.
                    • dougw03
                      • Jul 2012
                      • 12
                      Hmm I didn't see anything but a couple 100mv of what appeared to be noise on the test points for both the xsus and ysus. The only input that showed anything was the RST which was a square wave. Does this tell you anything?
                        It tells me that Vs is probably very low or some enable signal (aside from RESET) is not getting through.
                        • dougw03
                          • Jul 2012
                          • 12
                          Hm, so this sounds like a power supply issue?
                            Test the Vs with your meter; it should be marked on the power supply.
                            • PowerAmpFreak
                              • 982
                              • Sweden
                              Do you have proper VS and VA from powersupply at all?
                              • dougw03
                                • Jul 2012
                                • 12
                                For both the XSUS and YSUS boards...
                                Vg 20V
                                Va 60-66V
                                Vs 216V
                                • dougw03
                                  • Jul 2012
                                  • 12
                                  Anyone have any ideas?
                                    Vs looks a bit high should be closer to 200V. Is Va unstable?
                                    • dougw03
                                      • Jul 2012
                                      • 12
                                      Va fluctuates between 60 and 66V.
                                      • dougw03
                                        • Jul 2012
                                        • 12
                                        Can anyone please offer some advice about which board to switch first? I've been without TV for a long time now. THanks!
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
