Panasonic DVD recorder shutting down on disc spinning
  • japlytic
    • Oct 2005
    • 2086
    In a friend's Panasonic DVD recorder (I forgot the model, around 2004), the disc would spin up before shutting down and starting up again. When this happens, the voltages from the power supply disappear. The player works OK when it has warmed up, but about a week later, the same problem happened again, which I suspected a thermal problem.
    I then used a hairdryer to heat up some of the components. It had no effect, so I suspected there was an overcurrent being detected in the spindle motor.
    When it was sent into a repair shop, they found that the SMPS controller (STR-G6351) was faulty. So I was apparently right about some sort of overcurrent problem. But the SMPS controller was incorrectly sensing an overload in any case, even though all other components were good . I could have tried freezer spray on it, but the problem is now fixed.
    (Before I used the hairdryer on it, the power supply was ticking until it turned on - the repair shop was right about the SMPS controller!)
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Panasonic DVD recorder shutting down on disc spinning
    sounds like a bad lytic.
    bad ones often work better after warm up.
    most str chips i see bad are shorted.
    • Tom41
      • Oct 2005
      • 338
      • England
      This sounds almost exactly like the problem I had with my old VCR. After pressing power on, it would power off 1 second later. Eventually, if you keep pressing the power button, it stays on... but needs an extra 5 minutes to 'warm up' before it outputs a signal!
      Finally it died completely - I opened it up and found what appeared to be a bulged Panasonic FC. Proof that even 'good' caps can go bad sometimes...
      Open up the machine and see if there are any bulged or vented caps. If so, other components may already have suffered permanent damage.
      You know there's something wrong when you open your PC and it has vented Rubycons...
      • japlytic
        • Oct 2005
        • 2086
        As I said earlier, there are no bulging or leaking capacitors in this unit (mainly KY series in the power supply).
        • Ady2017
          Panasonic DMR-EZ48V DVD/VHS combo - DVD recorder part not working
          by Ady2017
          I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that...
          06-06-2025, 08:05 AM
        • Junior††
          PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
          by Junior††
          Good Afternoon fellas,
          Issue:
          Disc is showing as not supported when a disc is put in.
          Here's what I've done, you can skip this if you just wanna know the question:
          - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
          - reflowed the disc drive connector
          -reflowed the chip in question (shown on image)
          - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
          Question:
          I...
          02-19-2025, 12:48 PM
        • BigPete
          Panasonic Heatpump Dryer Repair
          by BigPete
          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
          Unfortunately the whole machine has to come apart to fix it.
          I have...
          11-01-2025, 06:40 PM
        • lcdcaps1
          Panasonic SAPM-31 Mini hifi, Tapedeck motor spinning all the time
          by lcdcaps1
          Hi
          I have a Panasonic SAPM-31 mini hifi and the tape deck motor keeps spinning all the time
          If I just connect the ribbon cable to PCB That is connected to the motor, it spins continuously
          If I change the input it still spins
          I have put it all back together with all the belts in place and still
          I can play, forward and rewind but the motor never stops when I press stop
          This never used to happen so I am not sure if a transistor has failed or a diode
          I will really appreciate the help from this forum
          Thanks all
          04-11-2022, 01:53 PM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
