Sylvania LC420SS8 Buzzing When In Standby
  • Mr Bill
    • Nov 2011
    • 648
    I picked this tv up yesterday. It was completly dead. Turned out to be a shorted schottky diode. Replaced it and the tv came to life. It physically works but the only issue (complaint) i have is the transformer emmits a audible buzzing noise when the tv is in standby. I used a cardboard roll and used it as a makeshift stethescope. There is no noise when the tv is on. I did notice on ebay there is a "repair service" for my issue. So this makes me think that it's a cheap and easy fix. I've tested all the diodes on the power supply but thats as far as i have gone.
    So what could cause this issue?
    Here is the link to the ebay auction for giggles even though i won't spend the $80.
    http://www.ebay.com/itm/Sylvania-LC4...item19d218a44b
    Thanks for any suggestions
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Sylvania LC420SS8 Buzzing When In Standby
    Send them an email to ask what the repair service does.
    --- begin sig file ---
    --- end sig file ---
    • Mr Bill
      • Nov 2011
      • 648
      I emailed them and asked if they would offer a repair kit. I'm sure you can guess what there answer was.
      BUT
      In the end i found out what was causing the issue. There was a service bulletin on this issue. D655 needed to be removed from the power suppply. So the repair service on ebay was to remove a little zener diode and charge you $80.
        Thanks for finding this, how did you locate the bulletin?
        • retiredcaps
          • Apr 2010
          • 9271
          They probably don't even bother to desolder it. Just take a flush cutter and snip off the diode and send it back to the customer.
          Despite my number of posts, I still lack a lot of knowledge. For example, I thought a zener diode or any diode was there to protect some part of the circuit. By *cough* hack *cough* taking this diode out, doesn't the customer lose something?
          Isn't it like a mechanic rebuilding an engine and finding one left over part and when no one is looking, chucks it into the garbage?
            The bulletin did not indicate that it is Zener Diode, it just indicates it as D655. Be good to see the diagram and what its function in the circuits is.
            • Mr Bill
              • Nov 2011
              • 648
              I actually found this on encompass parts website. The service manual parts lists calls it a "switching diode", so thats my mistake on calling it a zener.
              http://www.encompassparts.com/webwiz...model=LC420SS8
              • rass96
                • Jul 2012
                • 5
                Mr Bill which Diode was your original problem? I have one doing the same thing.
                • Mr Bill
                  • Nov 2011
                  • 648
                  D655 was removed and the buzzing in stanby went away? Does your board look like mine in post #1 since i see your from the UK?
                  • rass96
                    • Jul 2012
                    • 5
                    Yes its the same board, its a US spec TV ( I am USAF stationed here). No I mean for the original power problem. You said it was a shorted Schotkky diode? Just trying to narrow the search. But it did have the buzzing too, so that will get removed thanks to you.
                    • Mr Bill
                      • Nov 2011
                      • 648
                      I can't remember exactly which diode was shorted making it dead but it was one of the diodes i put squares around.
                      • rass96
                        • Jul 2012
                        • 5
                        Thanks, I will look at those more closely. When I was randomly testing diodes today I noticed like 4 of those had continuity but I think they had common connections. I will let you know how it goes.
                        • rass96
                          • Jul 2012
                          • 5
                          Ok I found a shorted diode, its the one on the right next to the tall cap in the bottom square. They are parallel so they both shot bad till I desoldered one to isolate. Its an SB 390 which is a 3A forward continuous current, 90V peak reverse voltage. I have a SB 360 on hand which is 3A 60V reverse. Do you think it would be close enough? Or do you think the difference is too much?
                            There's probably a reason they used 90V there, but the 60V will probably work for a quick test, I'd expect it to fail quickly though.
                            • rass96
                              • Jul 2012
                              • 5
                              Mr Bill
                              Just wanted to say thanks, the diodes came in the mail today (I decided just to order the right replacement rather than chance it) and I replaced the pair and the set came right up. I instantly heard the buzzing (very obnoxious) and clipped the D655 and it stopped. Thanks for posting that service bulletin.
                              • Jvercelli
                                • Jun 2013
                                Where did you buy the diodes from?
                                • tvguy12012012120
                                  by tvguy12012012120
                                  02-07-2025, 05:13 PM
                                • fharris1977
                                  Vizio D50u-D1 Dead Set No Standby
                                  by fharris1977
                                  Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                  12-28-2023, 10:25 AM
                                • Crystaleyes
                                  Samsung BN44-00259A standby question
                                  by Crystaleyes
                                  Hi all.
                                  I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                  SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                  Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                  The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                  08-11-2023, 05:15 AM
                                • psssst
                                  Yamaha TSX 120 Standby Problem
                                  by psssst
                                  Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                  03-01-2024, 07:25 AM
                                • ChristianBr01
                                  LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                  by ChristianBr01
                                  I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                  The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                  What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                  04-23-2025, 01:48 AM
