philips 42pf9946 plasma display problem
  • senndogg
    • Dec 2011
    • 383
    • Albania
    hello ladies and gentlemen.
    this is my second plasma repair so i want to give my best.
    i have no rich experience in plasmas so any help is praised.
    this is a Philips 42PF9946. the problem is shown in the pictures. the pdp seems to be Samsung S42SD-YD05, (from the back label).
    i havent opened the cover yet, but i'd like to know any early opinions.
    thanks in advance.
    Re: philips 42pf9946 plasma display problem
    Very likely a buffer fault.
    • senndogg
      • Dec 2011
      • 383
      • Albania
      thank you tom. i did some more searches and turned out this tv is famous for the notorious buffers. but the real problem is with the owner who refuses to pay any real money for repairing it. it sounds stupid but he claims to be some kind of technician and is convinced on "resoldering the tuner pins". he states it is an antenna connector problem. c'mon! cant troubleshoot the problem with this pressure
      i think i am forced to give up.
      anyway i'll make him an offer as he was totally broke, and revive this thread later.
      thank you for your attention!
      • retiredcaps
        • Apr 2010
        • 9271
        Originally posted by senndogg
        tit sounds stupid but he claims to be some kind of technician and is convinced on "resoldering the tuner pins". he states it is an antenna connector problem.
        Move on. There will be lots more in the future.
        --- begin sig file ---
        --- end sig file ---
        • scokljat
          • May 2012
          • 275
          • Croatia
          My guess is (other than buffers) maybe CTRL board...
          Cheers!
          Suad
          • senndogg
            • Dec 2011
            • 383
            • Albania
            thank you scokljat. i'll keep that in mind for later.
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • janos6662000
              Philips 47PFS7509/12 LCD TV problem
              by janos6662000
              Hi
              I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
              When i applied cable signal to check image, i had normal picture, but TV was restarting.
              I downloaded original firmware and applied the update, but the problem remained.
              From a colleague i received a "factory package software" which is a lot bigger.
              I made another firmware update, but still did not solve the problem.
              Somewhere on the way the error got worse, because at the moment the...
              08-12-2025, 12:54 PM
            • courtcircuit
              Philips HTS8000 home cinema noise problem
              by courtcircuit
              Hello
              I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
              Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
              Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
              I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
              Removed each of tyhe boards
              02-08-2025, 08:22 AM
            • celiabrown
              Issue with Plasma Philips 37inch chassis FTL2.1
              by celiabrown
              Hello guys,
              My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
              Can someone has any symptom like this ?
              Thanks​
              05-09-2024, 10:56 PM
            • bohaboha
              PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
              by bohaboha
              Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
              how to fix it thanks
              02-05-2025, 09:23 PM
