i love getting into component level i got this tv the other day it shows an orange light upon putting ac mains into the psu,
the standby 5 volts is there and sends out to the main board but im only getting 1.44 volts back from the mainboard to turn on the psu.
thought it must be being dragged down and sure enough if you remove the 5 volt logic between main board and psu the psu on signal from main board is a steady 4.98 volts ? this is pointing me toward the psu faulty
also its making a funny quiet squealing noise sounds about 13khz (maybe well off) but its not stable you can hear variations in the audio squeal which makes me think its caput
i think iv done the obvious (not great on switch mode) checked the rectifier transistors all check ok only thing i didnt check was the
