Help Needed PDP TV plasma tv. PDP-4201? Wont turn on. Symptons inside
  • aj11r
    • Jul 2006
    I bought this from a friend recently as a project to fix and possibly sell on, the tv can be seen here
    http://emket.en.ecplaza.net/3.asp
    His descriptions of the fault as it occured taken from my e-mail:
    This plasma currently does not turn on, just the RED LED light comes on when you plug it in.
    Ok, the screen initially had a fault which seemed to create a bar code distortion in the picture running horizontally in three places. Two at the top and one at the bottom. Between 1 and 2 centimetres in height. I managed to solve this problem/interfearnace by adjusting the box at the back of the plasma that houses all of the plasmas connections.
    This fault happened again so I ended up removing the rectangle box at the back of the plasma that held the connectors, this allowed them to hang free from any shorts that were happening. I found this to be fine as I never look at the back of the plasma and did not mind what state the connectors were in as long as they were safe.
    This solved the problem for some time until a separate fault has killed the plasma altogether. First I got vertical lines every 2 cm along the screen and then a few days later it refused to turn on. The LCD still lights but nothing more.
    I have had the back off the plasma and decided it was far to complex for me so abandoned it there
    Any help would be much apprectiated as i cannot find any circuit diagrams, or any thing on the internet about this tv except the link above.
    MODEL: PDP-4201
    Serial:K107PTOP10JB7
    I completed an electronics apprenticship a few years ago so i have some electronic experiance, but no with consumer products. [/i]
  • aj11r
    • Jul 2006
    Re: Help Needed PDP TV plasma tv. PDP-4201? Wont turn on. Symptons inside
    Ok so now i can get it to come on when i disconnect the PCB Controller board.
    The tv will come on and all fans working etc.. But iv noticed while its been on for a short time (thought id give it a soak test) 2 Capacitors Daewoo 1000uF 160wV (m)105oC , the tops of these bulged up???
    Any idea what they are doing, why etc...
    • Hagis2k
      • Jul 2006
      • 66
      Get an schematic over it and meassure all voltages check all major bigger transistors and diodes etc maybe you find the malfunctioning part it is also possible that an capacitor have been shorted there is so many thing that can be the problem...
      I would:
      * Check all voltages
      * Check bigger transistors for shorts
      * Check all diodes anode-cathode and vice versa they shall only lead one way
      Bulged capacitors are not an healthy sign just replace them
      Cant give you so much more help i think
      Is their an backlight in plasmas check it for shorts etc
      • aj11r
        • Jul 2006
        hi thank you for your reply.
        Unfortunatly i cant source the schematic to get voltage points.
        Although the boards to have test points on them.
        These points give the correct voltages once the pcb board controller board is disconnected, so i believe the whole power part of the circuit may be working ok?
        Iv ordered 2 new caps and shall fit them and see what difference they shall make.
        • mbates14
          • May 2005
          • 169
          yea, you need to change alot of capacitors in that thing.
          no, plasmas do not have a backlight, they generate thier own light. they are like a CRT, but not like a CRT. hard to explain. it works based off of gas-discharge that lights the phosphors.
          • fixiturselfdummy
            • Jul 2011
            yeah id first check the capacitors. its an easy fix. i made a do it yourself video on changing the capacitors. heres the link on youtube: http://www.youtube.com/watch?v=EbGiXqBAvvo
            • PlainBill
              • Feb 2009
              • 7034
              He's right, and it's informative. Parts are very funny. I found the part about 'burning the capacitor leads with a soldering iron' exceptionally amusing.
              PlainBill
              • chazh
                LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                by chazh
                This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                09-01-2025, 08:56 PM
              • pajdek
                Lenovo Y700-17ISK turn on and off
                by pajdek
                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                09-20-2023, 02:49 AM
              • Flaku_34
                Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                by Flaku_34
                Introduction:
                Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                04-18-2024, 12:47 PM
              • SACR
                Panasonic Plasma TH-P42X28K A-Board @ Mainboard Schematic needed
                by SACR
                I need Schematic A-Board @ Mainboard for Panasonic Plasma TH-P42X28K. Code : TNPH0842. I want to replace 1 MLCC but I don't know values (capacitance & voltage) & codes. Can someone help me? Thank you...
                11-20-2023, 11:53 PM
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
