Help- Vizio VW42L HDTV10A
  • XmouseX
    • Aug 2011
    • 158
    • US
    Re: Help- Vizio VW42L HDTV10A
    Ok so here are some more pics. the full back of the tv, the main control board, the tcon cable and the tcon cable + input power from power board(white wires).
    • retiredcaps
      • Apr 2010
      • 9271
      1) On the main board, are fuses F1 and F2 good?
      2) You mentioned that all the voltage regulators tested good in post #1. I'm assuming you meant all the voltage regulators on the main board like the infamous U33 and U7?
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        3) What is part number U32 on the main board?
        4) I forgot to award you one retiredcaps' bonus point for a picture of your Greenlee multimeter. I can't quite make out the model number, but I know I have seen pictures of it before.
        • XmouseX
          • Aug 2011
          • 158
          • US
          Yes sir U33 was 3.3V exactly , U7 was 1.27V and U9 was 1.53V. Also I checked F1 and F2. Both were 00.2 ohms and seemed fine.
          • retiredcaps
            • Apr 2010
            • 9271
            Did you see post #23?
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Service manual is at
              It does have a troubleshooting section. Maybe verify you did all the steps?
              • XmouseX
                • Aug 2011
                • 158
                • US
                #27
                Thank you so much for your time I do have the manual already. I am just not sure how the flow chart works when it says how is the inverter?...Um it doesn't work..lol. But it doesnt give you a next step after that. Well thank you for all the help anyway.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Focus on page 9-5. Test everything on that page inside the rectangular box. Report your findings for each box.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    I have more suggestion. Disconnect the LVDS cable from the main board. Now measure the DC voltage of LVDS pins 1, 2, 3, and 4 on the main board with respect to ground. Do you get voltage on any of them?
                    • XmouseX
                      • Aug 2011
                      • 158
                      • US
                      #30
                      Dont know if this matters, bu I just jumped 5V to pin 13 on J1 and the backlight came on....I will do the tests that you suggested. Thank you
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        Another suggestion. Please retest all the voltage regulators on the main board and list the pcb designation, part number, and readings for each pin like so
                        U33
                        AL1117-33
                        pin 1 = 0.0
                        pin 2 = 3.3
                        pin 3 = 5.0
                        Maybe we can spot something you missed?
                        • XmouseX
                          • Aug 2011
                          • 158
                          • US
                          #32
                          Ok so real quick I am still testing regulators, but the Voltage reading for the LVDS cable pinouts were...pin1=0V, Pin2=0V, pin3=2.4V and pin4=3.3V
                          • XmouseX
                            • Aug 2011
                            • 158
                            • US
                            #33
                            U33
                            AMC1117
                            pin1 - 2V
                            pin2 - 3.3V
                            pin3 - 5V
                            U7
                            AMC1117
                            pin1 - 0V
                            pin2 - 1.28V
                            pin3 - 3.3V
                            U9
                            AMC1117
                            pin1 - 0V
                            pin2 - 1.51V
                            pin3 - 3.3V
                            U8
                            AMC1117
                            pin1 - 2.05V
                            pin2 - 3.3V
                            pin3 - 5.15V
                            U2
                            AMC1117
                            pin1 - 1.45V
                            pin2 - 2.30V
                            pin3 - 5.10V
                            hope this helps
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #34
                              Originally posted by XmouseX
                              U9
                              AMC1117
                              pin1 - 0V
                              pin2 - 1.51V
                              pin3 - 3.3V
                              U2
                              AMC1117
                              pin1 - 1.45V
                              pin2 - 2.30V
                              pin3 - 5.10V
                              1) Are you sure about the part numbers for U9 and U2? In the picture, it looks like U9 is K1117S15? The 15 at the end indicates it is a fixed regulator outputting 1.5V which would make U9 a good regulator.
                              Please re-check all your part numbers and make sure it is not a cut&paste error.
                              2) U2 is an adjustable voltage regulator and it is bad. Pin 2 should be pin 1 + 1.25V or 1.45 + 1.25 = 2.70V. At 2.30, it is way too low.
                              • XmouseX
                                • Aug 2011
                                • 158
                                • US
                                #35
                                Yes those are the part numbers. The U9 that I mentioned earlier is on the TCON board. This U9 is on the main control board in the second set of pictures. It is confusing that there is 2 U9's.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  Not according to the pictures (which is why we ask for them - selldoor can back me up on this one).
                                  U9 on the main board is K1117S15. U9 on the t-con is RT9164A.
                                  U2 is bad. 52 cents at digikey.com
                                  http://www.digikey.com/product-detai...ICT-ND/1301524
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    To hedge my bets, the caps around U2 could be bad as well. Namely CE5, CE6, and others in that area. See post #38 below.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #38
                                      By the way, on page 9-5 on the service manual, it suggests that U2 should be 3.3V output.
                                      So pin 1 should be roughly 2.05V. Pin 1 + 1.25 = 3.30 for pin 2. So it is possible that the components feeding pin 1 are low or U2 itself is bad.
                                      • XmouseX
                                        • Aug 2011
                                        • 158
                                        • US
                                        #39
                                        My bad! you are are correct my friend. It is a K1117.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          Precision matters here. It is K1117S15. The S15 matters because it tells us the correct output voltage (1.5V). K1117 by itself suggests an adjustable regulator. So if pin 1 is 0 and pin 2 is 1.50, that means it is a bad regulator.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • Yanleb
                                            LG 60PK550 Logic Control Board EBR63450301
                                            by Yanleb
                                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                            C57: 3.30V
                                            C61:...
                                            07-20-2023, 12:38 AM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
