Insignia ns-lcd42hd lvds cable question
  • electronicsurplus
    • Jun 2012
    • 210
    I have a Insignia NS-LCD42HD and lost the lvds cable
    Does anyone know the proper pinout or, where I might obtain a replacement LVDS cable for this set
    It uses the Polaroid type control box setup
    Thank you
    Jon
    Electronic Surplus
    This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
    Help keep these from the landfills
  • ResoluteHawk
    Connecting an LVDS/eDP cable into a live motherboard
    by ResoluteHawk
    Could anyone explain the reasoning behind why connecting an LVDS or eDP cable into a laptop motherboard, with the battery still connected, kills the CPU/PCH/SuperIO/GPU?
    Today I had a customer with a Lenovo Legion 5 that I diagnosed as a dead iGPU inside their Ryzen 5900HX. They told me that they connected their screen to the motherboard without first disconnecting the battery.
    I want to understand the nitty gritty behind why it kills components if power is not disconnected first.
    08-04-2025, 04:39 PM
  • alfredomfr1
    HP M32f FDH Monitor: 12v missing after connect the LVDS ribbon cable to the LCD circuit
    by alfredomfr1
    12v pin is shorted to ground in the LCD board (1st picture) if the LVDS cable is disconnected, 12v are OK in the Main Board (2nd Picture)
    06-04-2025, 10:23 AM
  • Patch2
    Cable Repair
    by Patch2
    I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
    01-02-2025, 06:04 PM
  • mon2
    A1466 Macbook Air (Liquid damage repair)
    by mon2
    Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
    Macbook AIR Model A1466 Diagnostic 09-01-2021
    Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
    Problems & Resolutions
    1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
    09-01-2021, 09:31 AM
  • NolesFan
    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
    by NolesFan
    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
    10-24-2024, 06:36 PM
