Re: Panasonic TC-42PX14 Zener Diode
Solder pin 3 and 4 of the Opto IC600 together, then plug the TV in, then you should see IC603 pin16 and PIN1 of IC502 goes HI.
I checked the IC 600 Opti-Isolator. pin3 no voltage at
all, pin 4 a little less than a volt. I jumped them to see, if
I would get less than a volt on both pins, now no voltage.
So, I take it that IC 600 is defective.Leave a comment:
O.K. will give it a try, have to pick up my Grand daughter in Turlock.If you follow the AC fail H signal on the PDF, I have notes as to what you should have at the test points.
On the first page, the OPTO isolator IC 600 PIN 3 and Pin4 should have less than a volt at those pins.
You can short pin 3 and pin 4 of the IC600, then you should have the 17v OUTPUT at pin 4 of the IC502.
I see you are from the bay area, worked there for 25yrs, east bay
mainly. now disabled and retired. will give you results later.Leave a comment:
As you can see, when you have AC feeding the TV, AC DETECTOR IC200 will send the signal to turn on IC600 which it then sends the LO signal to IC603 pin 19 to tell IC603 that it detect main AC input, then IC603 pin 16 will send out a HI signal to turn on 15V regulator IC502 to turn on its output to send out the regulated output at pin4.Leave a comment:
Should I just back track from pin 1 and check caps, diodes etc.
also Q505 does have the 5volts on 2 pins.Leave a comment:
You are getting the Input to the regulator OK, but the ON/OFF control pin 1 is not getting the ON control to turn it on, that can be due to detector circuit that monitor if circuit is getting AC to the TV. Please see the revision 2 of the PDF.Leave a comment:
budm, replaced battery on Amprobe Digital Meter, and get same
results. No voltages at pins 1,3,5, but it is strange pin 2 gets
around 18 to 19v. Got out my reliable Analog meter, and same
results. On the pins 1,3,5 needle did not even move, on pin 2
it read close to 18vdc.
You mentioned if pin1 is not working possible problem in AC
circuit.Leave a comment:
yes, pin 2 was 21v, after I fix my meter, will try again.Leave a comment:
But you do get Voltage at VCC pin 2, right.
I updated the PDF to rev2 showing the on/off control of the IC502.
Since the Control signal at pin 1 is 0V, it means that it detects AC FAIL some how.Attached Filesif you find these attachements useful please consider making a small donation to the site
pins 1,3 and 5 had no voltage. Yes, I will check my meter. but it seems
stable when I measure the 5v standby.Leave a comment:
Pin 1 is the ON/OFF control pin, I expect 5v or higher, if it does not have any voltage at this pin, there will be no output at pin 4. Do verify that your meter has accurate reading.Leave a comment:
That was the first IC I took voltage pin 2 was 21.3v first reading, secondYes, the standby power supply will start running the minute the power plug is plugged into the outlet. All TVs need standby power supply to run the processor on the main board and the remote receiver so it will be ready to take command to turn on the rest of the power supplies from the power switch or from the remote control. This is how TV uses less power when it is not on.
Are you getting any DC at IC502 PIN2 VCC input pin? and the voltage reading on the rest of the pins of IC502.
Since you are getting the 5V, that means the transformer is working.
reading 19.5v, after that got no reading, meter readings not stable.
Also T200 pin 18 at first reading 21.1v. I will try again tomorrow, once
I get a new 9v batteryLeave a comment:
Since you are getting the 5V, that means the transformer is working.Last edited by budm; 06-21-2012, 10:43 PM.Leave a comment:
Will take those voltage readings tomorrow, seems my Amprobe 38
meter, needs another battery. Readings flucuate.
budm, so standby should always be there, without powering up
unit, correct? The only voltage i get on P6 connector is the
5vstandby. That is with just the power cord plugged in.Last edited by mr.sky; 06-21-2012, 10:32 PM.Leave a comment:
I will check it out, I also tried another new power supply boardIC502 is the standby power supply (15V) which should be always running. The other power supply circuits is right below it is also always on, do you get any voltage there? There should be voltage at Q505, that section is for the standby 5V power supply.
Basically, transformer T200 is for standby 5V and standby 15V power supply, so you MUST have these voltages.
that I received last week. And the same results.
Who knows could be bad too, good thing I got it for 30bucks.
I am looking at page 32, and on top of board, there is a 3
leg diode, looks like a regular size voltage regulator, but it is
a diode, D502. Going to have lunch and test voltages like you
mentioned above.Leave a comment:
Basically, transformer T200 is for standby 5V and standby 15V power supply, so you MUST have these voltages.Leave a comment:
budm, Thanks for the diagrams. let me update you and others whoOK, I figure out where the F15V is generated from, see PDF/JPG attached.
This F15V is called F15V_STBY which is the always on standby power supply.
So you need to check the voltage at the IC502 which generated the regulated F15V voltages for a lot of circuits as I redlined.
are following this thread.
On first diagram where IC502, I am not getting 15v at all.
Before I press the power button, reading is at 3.0v. Once
I power up unit it goes to 5.4v, same reading I get at the
A Board at IC 5401 and IC5608.
Also, Pins 7,8,9 same voltages at connector P6.
The unit is only come on for a few seconds, enough to take
a reading then shuts down within 5 seconds.
Note, I took the reading from pin 4 of IC502Leave a comment:
So you need to check the voltage at the IC502 which generated the regulated F15V voltages for a lot of circuits as I redlined.Attached Filesif you find these attachements useful please consider making a small donation to the site
budm, read Slide #28 the last paragraph. I think this is why
I am not getting F-15v from outpins from power supply board.
There is a 3.3v 6pin voltage regulator on the component side of
the A board, maybe this is the one that triggers the command to
to acitivate the The PANEL MAIN ON command turns on the power supply circuit that outputs the Vsus, Vda, 15V, and 5V.
Let me note my A-board does not have IC 9004Last edited by mr.sky; 06-20-2012, 11:22 PM.Leave a comment:
by unimatrix93Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
The led strips has 9 6V leds.
1 Photo -
by sam_sam_samI have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
I bought this from an eBay seller but unfortunately they only had one
I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
I bought three of from them to also make battery packs with this output power limit in mind
I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery... -
by nev1001Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
I think an issue could be a zener diode (or capacitor) which has shorted out.
The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...-
by Vincenzo2My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
I put some pictures here to show that it is labeled "M7".... -
by hobostoveHey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
There's a 22ohm resistor that's melted and open, but it still has the bands.
The other part is a zener diode and it's top went to jesus, so I can't read the marking.
It looks like the diode connects the source and drain of a TNY284... - Loading...
