Polaroid FLM-3201 flickering
  • aerospacejackson
    • Jun 2012
    • 19
    • united states
    Screen not lighting up but when it does the TV flickers when it is turned on, If the TV has been off for a few hours, like in the morning or when i come home from work,after its been on about 5 mins the flickering stops, then if its turned off and back on everything is fine, It appears like a problem when its warming up, sometimes i have to leave it sitting blank for 20 mins to an hour and it will start flickering at which point if i turn it off and on ill get a picture. If it helps when it flickers i can also hear static through the speakers.
  • DrvLikHell
    Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
    by DrvLikHell
    Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
    The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
    07-05-2024, 02:54 AM
  • Jaysean
    Acer VN7-591G-70RT Display Flickering
    by Jaysean
    Hello Badcaps coummunity hope you all are having a bless day,
    Hope I didn't post it wrong kinda new at forum site rules and tradition
    So I'm dealing with screen flickering problem on my laptop.
    I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
    so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
    [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
    [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
    10-27-2023, 10:22 AM
  • reessi
    ACER BM320 Monitor - Horizonal Flickering Lines After a While
    by reessi
    The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
    They are black on the right and gradually fade to nothing on the far left.
    They start either after 5 mins or up to 2 hours after so annoying for testing.
    They flicker continuously very fast! With a slight pause milli-second every second.
    Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
    I tested each half by removing the first the left flex from...
    06-03-2025, 09:58 AM
  • arctor
    LG 55uh661v flickering images and lines
    by arctor
    Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
    06-16-2025, 11:57 AM
  • Adenitz
    Cutting the jumper on Samsung TV to solve the flickering
    by Adenitz
    Hello to all,
    I have just seen this YT video about solving flickering issue on SAMSUNG TV. Reading many comments it seems this works.
    But I wonder what is done here and how this solved the issue. I'm not able to find the schematics so cannot explain to myself.
    Few years ago I had a flickering problem on one monitor in some factory which I managed to solve by inserting UPS between monitor and power outlet. I also notice on this occasion the flickering was gone if I put insulation tape on the power plug like shown in the attached picture to remove connection with the PE conductor...
    01-06-2024, 12:20 PM
