Sony KV-32LS60B - CRT - Colours a bit off
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    Picked up one of these recently, has an AE-6B chassis. Works fine, although the colours seem to be a bit off, don't seem to be as vibrant as I would have expected, so I'm wondering if anyone has had any experience with these sets, and is there anything I can do to improve the colours?
    When I adjust the colour, I can get it on the scale to go from B&W to completely exaggerated colours, but somewhere in the middle where you would expect it to be ok, they just don't look right, so maybe it's an issue also involving the contrast and brightness. It's hard to explain, not sure if photos would help. I mean, greens look green, and reds look red, but it's hard to get an overall satisfactory picture through the adjustments. Whilst some of the background colours may be ok at one setting, skin tones look a bit pale, for example.
    In the service menu, I can see that there are nearly 27,000 hours on the set, so possibly the tube is the problem here?
    I can post pictures if anyone thinks they would help. I have another 21" CRT or a 26" LCD that I can post comparison pictures of the same feed, or what is the best way to take them?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Sony KV-32LS60B - CRT - Colours a bit off
    Yes. An aged tube will behave like you described. You're going to have to live with it.
    A working TV? How boring!
    • tmcw
      • Oct 2010
      • 382
      • Ireland
      Thanks, I was thinking it might be that alright. I was watching a film the other night, but found myself thinking that the picture was quite acceptable, not sure if it's because I'm getting used to it, or maybe the colours are improving after the set being on for a while.
      Anyway, one thing I've noticed (particularly when there is an on-screen banner towards the bottom of the screen), is that the lower right corner of the picture seems to drop slightly. When I go into the service menu, there are a lot of options in the "Geometry" submenu, so I'm wondering what menu item I should be looking for to try and correct this?
      The picture was a little big also, and I can see options like VSIZE and HSIZE for adjusting these, but I'm wondering if there is somewhere where I can find out what all the variables mean, like AFC BOW, AFC ANGLE, PIN AMP, etc. I've written down all the names and their current values, but are there some I shouldn't touch?
      Finally, is there any good resources for how to set up these types of TVs, like what to use as an input for setup (or is more specialised equipment needed), and how to approach getting the optimal settings, like which variable to start with?
      For instance, in the "Service" submenu, I can see values for "SUB COL", "SUB HUE", sharp, bright, cont, and RGB drives and cutoffs. Where can I get some good information on what these mean/do. I'm afraid to muck about with any settings really unless I mess it up completely. I did get the service manual for the set, but it has no details like what I'm looking for.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        I'm only experienced with Trinitron monitors, not TVs, but at least the monitor tubes have a pretty long warmup period (30 minutes or so) till they reach maximum quality.
        If only one corner drops this indicates a physical fault in the deflection coil (manufacturing defect), and cannot be fully corrected. You're welcome to try though.
        Unless you have a colorimeter, or there's something really wrong with the brightness/contrast/colors/hue, i wouldn't touch those right now.
        Anyway. Here's what i would do. I see this is a standard def (non HD) set. Get yourself a copy of the Avia Calibration Disc and pop it into your DVD player. That disc has every service pattern you need on it.
        Now for what you want to tweak. First lower HSIZE and VSIZE so that the set underscans and you can see the edges of the picture. Start with the "brightness and contrast" pattern and follow the instructions on the disc. Next apply a crosshatch pattern and do geometry. Finally, go to the Overscan Bounce pattern and set picture dimensions/positions so that the overscan level is as low as possible, but not low enough that it underscans when brightness changes.
        A word of warning: Some DVD players have an offset to the picture, and the H position will be wrong. Double check this with TV program material afterwards. Of course, if you mainly use it for watching DVDs, then don't worry about it.
        If the colors still seem a bit off after you've completed the other adjustments, you can mess with the cutoffs, but it's complicated. I'll try to explain later if you need it.
        • popeye
          • May 2011
          • 155
          the correct way to set the colour is first use colour control to turn colour to minimum
          next adjust contrast and brightness for a perfect black and white picture
          when you have that right bring in the colour till it is as you like it best domne on an outside broadcast like horse racing.
          • tmcw
            • Oct 2010
            • 382
            • Ireland
            Thanks for the replies guys, it took me a couple of days to get the Avia disk, but I have one now, and playing around with that. I have a feeling the warmup period is important, maybe I wasn't waiting long enough initially, and maybe the components are taking longer than normal to get up to good working temperature, given their age. Or maybe I'm just getting used to it. Either way, I'm happy enough with it for now.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Kind of off topic but I didn't know you could check running hours on a tube TV. How do you do that?!
              • tmcw
                • Oct 2010
                • 382
                • Ireland
                It's fairly easy to see on this set at least...
                Put the RC into service mode, call up the service menu, go to the "Error Menu" submenu, and the info is displayed at the bottom as "Running Time" in hours and minutes.
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
                • dkneyle
                  Sony KDL-46HX850 Can't upgrade/update firmware
                  by dkneyle
                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                  09-25-2024, 10:44 PM
                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 05:27 AM
                  Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                  This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                  09-06-2024, 05:30 AM
                  Sony VAIO SVE1413XPN Notebook E Specification for Upgrade or Repair
                  This specification for the Sony VAIO SVE1413XPN Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVE1413XPN boardview and SVE1413XPN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony...
