Sony KDL-46Z4100
  • JayArr_BC
    • 65
    Sony KDL-46Z4100
    Hello All
    I have the above TV in my shop for what was called a "flicker".
    The screen brightness? or contrast? would go up and down making the screen appear to flicker.
    My first thought was the backlights but pulling the connector from the tcom put them on and they are solid and steady.
    Next I thought it was a bad tab connection so I swapped the entire panel - it's still happening!
    So I started looking at voltages with my scope and noticed they are all jittering about, I followed back from the Tcon board to the main board and then into the power supply board and found it jitters all the way back to the 12V and 15V from the power supply.
    To make sure it wasn't a load problem I disconnected the outputs from the power supply to both the inverter and the main board and applied AC, I only get the 3.3V STBY but it's flickering too!
    Since the 3.3V STBY and the 12V and 15V lines come from different transformers and ICs I thought that maybe the 395 PFC was bad but while trying to measure it all I did was blow the main fuse. HINT: don't hook a grounded scope lead to the 395V PFC ground - they aren't the same
    So before I start ordering and replaceing CXA ICs or FETs I thought I'd ask if anyone else has seen this and could give me a pointer.
    Jeff
  • russianbar
    SONY KD-65XE7002 Screen Flicker
    by russianbar
    This isn't my video but it's a fair representation of the fault I have, starts with slight screen flicker as the set warms up which happens every 5 seconds or so that gets more regular until more or less constant https://www.youtube.com/watch?v=Un8cAjUtOvA was thinking T-Con but open to any other ideas as seems to be quite a common fault on these
    04-10-2025, 03:11 PM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • thstuff
    Sony OLED XR-77A80J - Initially dead, now 4 Flashes
    by thstuff
    A) TV initially dead
    B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
    C) Was able to perform a Reset from Settings menu and completed out of box configuration.
    D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
    E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
    12-26-2024, 09:10 PM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-06-2024, 05:27 AM
