Re: Vizio E321VL
There are several threads on this model which I have read thoroughly. I will go back and reread them again.
Vizio E321VL
Re: Vizio E321VL
Re: Vizio E321VL
Can we have a close up picture of the two areas where I thought the traces were broken.Leave a comment:
Re: Vizio E321VL
I am sure you are not the only that has this TV with this symptom, may some one in this forum had worked on this model.Leave a comment:
Re: Vizio E321VL
There is 5V standby voltage to run the processor, when power switch is activated, the processor will send out PS_ON signal to turn on the Main power supply 12V/24V section.
We will need the diagram of the main board to find out where the PS_ON is at which IC.
I wrote this for FIXYA years ago:
LCD Flat panel TV troubleshooting guide
http://www.fixya.com/support/r509388...shooting_guideLeave a comment:
Re: Vizio E321VL
Re: Vizio E321VL
If I understand correctly there is a small voltage signal constantly from the power board to the main board, then the main board sends back a signal for the power board to send out the 12 and 24volt to the inverter and LCD control board.
I have not done anything other than measurements on the main board or the inverter board. Checking for voltage across the two fuses on the inverter board there is a 0 voltage reading so it does not appear that board is getting any power from the power board.Leave a comment:
Re: Vizio E321VL
U8 is fine, it is Adjustable to put out very low limit of the regulator, 1.25V.Leave a comment:
Re: Vizio E321VL
They do not always print everything on the PCB.
So U4 PIN 1 is 2.05V, pin 2 is 3.29V, PIN 1 and PIN 2 is 1.243V
then 2.05V + 1.243V = 3.293V, so it is OK.
The key point for checking the Adjustable regulator is to measure pin 1 and pin 2 voltage, it should ALWAYS be 1.25V (+/-3%), if not, then it is bad. Then you add this 1.25V reading to the pin 1 reading, that will become your output voltage at pin 2.
U5 looks like Adjustable also and the voltage looks OK if PIN1 and PIN 2 reads 1.25V, then 1.25V + 0.549V = 1.799V. U5 is good.
U8 it looks like it is a fixed regulator, pin 1 should read less than 1 Ohm to Ground, and the number as printed on the body should be some thing like 1117-1.25. Post the picture of this U8 so I can see how it is hooked up.Leave a comment:
Re: Vizio E321VL
Re: Vizio E321VL
Reading left to right with tab on top
U4 = 2.05 3.29 5.23
U5 = 0.549 1.79 3.32
U8 = 0.0 1.24 3.32
On the connector between the power board and main board on Pin 1-3 I am reading 5.24v as is printed on the label for that connector. The only other pin that I get any reading from is #13 which reads 0.430v the rest of the pins I get some kind of negative reading in the MV range.Leave a comment:
Re: Vizio E321VL
If you are getting 2.05 on pin 1 of u4, then it is not FIXED output regulator since pin 1 is not at ground potential.
What voltage do you get when you put the probes on PiN 1 & 2 of U4. It should be 1.25V.Leave a comment:
Re: Vizio E321VL
No, unfortunately it doesn't work like that. Measure the output - adjust voltage. Let's say it is 0.5V. It should be 1.25V. Let's say the output is 1.33V. The output voltage should be: 1.33V * (1.25V / 0.5V).
If you have a faulty adjustable regulator, you should replace it with an adjustable regulator.
Since on U4 I am getting a voltage reading on Pin 1 (2.05v) and no continuity to ground on that pin it makes me think that it is faulty. From the looks of the board U4 Pin 1 should go to ground and not have a voltage to my way of thinking at least. I hope this makes sense.
Again I have been wrong before and am sure I will be wrong many more times. Being corrected won't bother me at all. I wish I could get a Service Manual for this model, but have not been able to find one.Leave a comment:
Re: Vizio E321VL
If you have a faulty adjustable regulator, you should replace it with an adjustable regulator.Leave a comment:
Re: Vizio E321VL
Very sorry to hear the bad news.
This is applied to adjustable regulator 1117 series:
Voltage between pin 1 and pin 2 should always be 1.25V. There will always have one resistor between pin1 and circuit ground, and there should be a resistor between pin 1 and pin2. If you do not get 1.25V between pin 1 and pin 2, the the regulator is bad.
Fixed output 1117 regulator:
There is no external resistors since they are inside the regulator.
Pin 1 will always be connected to the circuit ground, the output pin 2 should put out the regulated voltage as printed on the body of the regulator and should be within 3%.
The "Vin = Vout + 2V" means that Vin must be at least 2V higher than the out put voltage that you want to regulated, it can be +3, +5, etc.Leave a comment:
Re: Vizio E321VL
Re: Vizio E321VL
Well things did not go well at the hospital. This was my wife's cousin and he passed away.
I have done some reading in the other threads on Vizio's as I have had time over the last few days. According to one post you wanted the values of the two resistors under the legs of the U4 LDO AMC1117 to help calculate the Vout and Vin. The two readings I got were:
R1 = 179.9ohms R2 = 109.8ohms. However, that only appeared to be applicable to the Adjustable regulators.
Another formula I found in the data sheet was Vin = Vout + 2V using the voltage readings I took on U4 Vout is 3.3V so Vin is 5.3V. Is this correct?
In another thread I read that there should be continuity between the first leg of the regulator and ground. I get continuity on the first leg of U8 and U5, but I don't get it on U4. Does this indicate that U4 needs to be replaced and if so is the 3.3V fixed version the correct regulator to use? None of these 3 regulators have anything printed on them but 1117. The U8 & U5 I believe to be adjustable regulators since that is printed on the board. Just for info's sake the readings I got on U4 are Pin1 = 2.04v; Pin2 = 3.29v and Pin 3 = 5.23v. Reading left to right with tab at top. U8 was Pin 1 = 0.00, Pin 2 = 1.24 and Pin 3 = 3.32v. U5 was Pin 1 = 0.549, Pin 2 = 1.79 and Pin 3 = 3.32v.Leave a comment:
Re: Vizio E321VL
Thanks for letting us know - family and health come first on here, just re activate the thread when you are ready.Leave a comment:
Re: Vizio E321VL
The minimum voltage difference between pin 3 (input pin) and pin 2 (output pin) needs to be at least 1.3V for the regulator to regulate, for example, if you want to have 2.5V output, the input voltage must be at least 3.8V if it is less than that, the output will not be able to maintain 2.5V output. This is applied to both Fixed and Adjustable.
The adjustable regulator, the voltage between pin 1 (adj pin) and the output pin 2 will always be 1.25 (this 1.25V precision voltage reference is inside the IC). For example, if you have adjustable regulator with the resistors between pin 1 and ground, and second resistor between pin1 and pin2 to set the out put voltage to be at 3.5V. The voltage reading between pin 1 and pin 2 must always be 1.25V (if the precision ref voltage circuit is working), then the voltage reading between pin 1 and ground should be = 3.5 - 1.25 = 2.25V. At the same time, the input voltage has to be at least 3.5 + 1.3V = 4.8V minimum.
The fixed regulator has the resistor network inside the IC, so you can only verify the input and out voltages only, you cannot get access to the 1.25V precision voltage reference circuits inside.Leave a comment:
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
Assuming...7 Photos -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
