Olevia LT37hvs
  • eagle00799
    • May 2012
    • 322
    Olevia LT37hvs
    I inherited this lcd tv and I know they are out of business but I thought I would give it a shot . When plugged in it immediately gets to come on, the blue olevia light comes on and then goes off and I get a blue screen for about 5 seconds then back to a black screen and the blue olevia light flickers then the blue screen comes on again and there is no sound .It repeats this over and over and the buttons have no control and I have to unplug it. I took the back off and plugged it back in and on the power supply there is a buzzing and clicking sound that coincide with the blue screen coming on then the click and the blue screen shuts off. The sound is coming from a transformer?? That is wrapped in yellow tape. I unplugged the inverters and get the same buzzing and a click then I unplugged the t-conn board also and still the buzzing and click. I'm not sure how to test the transformer but could something on the control board be causing it to overload and trip off and on? I hate to throw this out cause the lc370w01 panel is in other 37's and I believe its good. I will post pics in a bit.
  • eagle00799
    • May 2012
    • 322
    Re: Olevia LT37hvs
    some pics.
    • electronicsurplus
      • 210
      Re: Olevia LT37hvs
      Can you post a clearer and up picture of the Power supply and, the plugs on the power supply while they are unplugged?
      jon
      This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
      Help keep these from the landfills
      • eagle00799
        • May 2012
        • 322
        Re: Olevia LT37hvs
        Hope these pics will help.
        • eagle00799
          • May 2012
          • 322
          Re: Olevia LT37hvs
          Any idea where to go from here Electronicsurplus?
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • gbbradshaw
            Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
            by gbbradshaw
            Hi.
            I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
            02-22-2023, 01:31 AM
          • siuras676
            Dell XPS Plus 9320 blue screen and rebooting
            by siuras676
            I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
            First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
            However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
            Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
            04-07-2025, 12:10 PM
          • Abdulrhman Alabsi
            Dell precision 7530 blue screen
            by Abdulrhman Alabsi
            I have problem in my laptop, When I try to enter to windows it showes me blue screen, I changed hard driver and ram but it did the samthing...please give me the solution of it
            02-09-2025, 10:39 AM
