Lg 50pc3d-ue
  • Tokae
    • May 2012
    • 11
    Re: Lg 50pc3d-ue
    I haven't had a chance yet to grab the multi from work.. Crappy! But I am still looking forward to testing this TV and hopefully getting it working!
    • reessi
      LG Plasma ZSUS Flashing Screen, No Booting! - 50PB690V
      by reessi
      Replaced Zsus beginning of year as most transistors were short stopping tv powering up.
      Now screen flashes on off continually and ZSUS ticks. Looking like replacement maybe faulty or could something else cause it to shut down.
      If I remove both tabs from ZSUS to screen but keep all other connectors to ZSUS on then TV boots properly but screen very dark without ZSUS output, no ticking from ZSUS. So it only shuts down when under load from screen.
      If it is ZSUS then how to fault find, I already looked for shorts. No transistors shorted or caps and its...
      12-13-2017, 01:18 PM
    • alfredomfr1
      TV Plasma LG 60PN5000 ZSUS 15v missing
      by alfredomfr1
      All Voltages are OK except ZSUS 15v.
      YSUS board disconnected still 15v missing.
      ZSUS was replaced: 15v missing.
      Any help will be appreciated...
      04-29-2022, 11:26 AM
    • Salvatore057
      plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
      by Salvatore057
      I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
      Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
      I am lost, should I change the YSUS board? Is the YSUS board damaging...
      04-29-2018, 01:29 PM
    • JDC
      LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
      by JDC
      Make and Model: LG 60PB6650-UA
      Issue: Turns on, no backlight, can hear static (no channel)
      I've been repairing TVs for a couple years now. I know how to use a multimeter for the most part and know how to test most components for shorts.
      The power board connects to the ZSUS and then connects to the YSUS. The ZSUS is where I believe the failure is because the 16v line is only 3.8V, even when I disconnect the ZSUS from the YSUS.
      This particular model seems to have a common failure with its YSUS. My goal earlier was to prove the YSUS was bad so I could...
      09-13-2018, 02:12 PM
    • JarrodHook
      LG 60PZ570 - Zsus replaced, still have issues
      by JarrodHook
      I have had a interest in electronics forever, and as a hobby have tinkered with repairing things, taking them to bits, and so forth.
      However, I have a LG 60PZ570 that is causing me to rethink my life!!
      I purchased it for $100 as it had no picture, got it home, and it has the classic ZSUS issue, where in the picture is splotchy and dark.
      I checked the ZSUS board and determined there were a few blown transistors, fuses, etc.
      I looked up the repair kits, but the $70 shipping fee was a bit steep for me (I live in New Zealand)...
      03-17-2017, 09:53 PM
