17PW20 PSU Working but no power lights on LCD
  • shepp
    • Mar 2012
    • 377
    • England
    Re: 17PW20 PSU Working but no power lights on LCD
    I need an esr meter really, I'm thinking about making one tho
    • vinceroger69
      • Mar 2012
      • 6714
      same as but saving up for one of rusmikes ones he does a very good price shipped to the uk.
      • shepp
        • Mar 2012
        • 377
        • England
        you got a link for it....so i can have a look
        • shepp
          • Mar 2012
          • 377
          • England
          37" up and running Saturday, just swopped main board and its working a treat
          thanks guys for the input
          gods knows how meny ive fixed now...thanks to this forum
          • shepp
            • Mar 2012
            • 377
            • England
            BAD NEWS the goodmans has returned with similar fault, although ive found that its something to do with the 3v yellow cable that goes to the back light, any ideas what to check or replace on this circuit? ive noticed that when the tv is brought out of standby there is no 3v to the back light all other voltages are stable, but when there is the 3v's the tv works ok but then switches off after about half an hour, it sounds like a bad cap but ive replaced all the main caps
              The Vestel main board will do a self-test when first plugged in, if this fails it will go into "lock out" mode where it won't do anything. So, check the 24V peaks to 24V briefly. Honestly, these power supplies are so much trouble. I just replace them with a refurb 17PW15-8 or similar, those seem to last.
              • shepp
                • Mar 2012
                • 377
                • England
                #27
                i have noticed on some repair kits there is a voltage reg 5v, and C901 cap i havent replaced them, so for the sake of a couple of quid im gonna get the C901 cap first which is 4.7uf @ 50v then see if that does it, cant see voltage reg being faulty if im getting 5v stable,
                24v comes on, then when the set powers back to standby when the 3v isnt present it shuts down the voltages so all the other voltages are fine.
                only caps that will be left to replace will be the little ones, 100uf 16v etc, im determined to try and fix this one because ive replaced so many parts im sure it will last a long time, but saying that theres only so much on one tv you can take.....lol
                  See the tiny red caps near the big transformer. These tend to fail o/c.
                  • shepp
                    • Mar 2012
                    • 377
                    • England
                    #29
                    ive changed them already, so they should be ok
                      Yeah, they could have failed again. Just check them on a cap meter.
                      • shepp
                        • Mar 2012
                        • 377
                        • England
                        #31
                        there reading 34nf in circiut, both are, so gonna take them out tomorrow and retest because they should only be 15nf
                          If they are reading a higher capacitance they could be leaky and this could be a sign of failure.
                          I'd estimate ~85-90% of these Vestel PSU failures are due to them.
                          • Dani_2024
                            by Dani_2024
                            10-28-2024, 05:06 PM
                          • Asraf Atb
                            by Asraf Atb
                            01-27-2025, 05:02 PM
                          • JSin21
                            Compatibility of main boards between different variations of samsung MU6100
                            by JSin21
                            Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                            I have Samsung Smart TV UA65MU6100WXXY version DA01
                            Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                            11-27-2023, 04:54 AM
                          • jb_Bak
                            by jb_Bak
                            CN6401
                            Pin 01 NC
                            Pin 02 NC
                            Pin 03 "BL_ON": 0V
                            Pin 04 "N/C"
                            Pin 05 "STBY 3.3V": 3.5V
                            Pin 06 "GND": N/C
                            Pin 07 "AC_OFF"...
                            09-27-2021, 04:52 PM
