Wharfedale LCD42F1080P comes on but then picture turns off
  • shepp
    • Mar 2012
    • 377
    • England
    picture comes on then turns off but sounds still there, ive tried to check transformers but havent found anything yet, the transformer boards are CMO I420HI-20B any ideas any one? no bad caps that the eye can see
    will post pics if need, but be good if someone can point me in the right direction
    Transformers are 4023Q's (cant find data sheet to check what the readings should be)
    and cant find service manual for this model of tv
    Re: Wharfedale LCD42F1080P comes on but then picture turns off
    Good 24V to inverter?
    • shepp
      • Mar 2012
      • 377
      • England
      will test that tomoz, if its low will the back light still come on to start with?
        PSU can sometimes start with good 24V and then drop out.
        • shepp
          • Mar 2012
          • 377
          • England
          right tested 24.55 VDC so thats pretty stable
          • shepp
            • Mar 2012
            • 377
            • England
            right ive just measured accross the supply 0V's and i get 21v on the first black wire then 23v on the second black and only 16v on the third black coming from the Power board theres no markings on the board to see what there for but ill post a pic any way in 2mins
            the measurments are using one red wire from the 24v + then from right in the pic to left (black 0v)
            • shepp
              • Mar 2012
              • 377
              • England
              pics
                Oh dear. It's a 17PW16. 37/42" LCD PSU.
                Report the voltages on connector with orange/blue wires please.
                • shepp
                  • Mar 2012
                  • 377
                  • England
                  Is that bad? Lol
                  From right to left (blue to red)
                  Standby
                  1. Blue 5v
                  2. Orange 3.4
                  3. Orange 3.4
                  4-6 black 0 v
                  7-9 red 1.3V
                  10 is empty
                  11+12 red 0.7v
                  When on 11+12 change to 5v and rest remain same as above
                    The 17PW15, 16 and 20 supplies are probably the worst power supplies I have ever encountered in an LCD TV. They are designed and manufactured by Vestel.
                    Can you post a picture of the inverter?
                    • shepp
                      • Mar 2012
                      • 377
                      • England
                      this is only pic ive got coz ive put the covers back on to test voltages (model : I420H1-20B-MASTER / SLAVE)
                      but these are the same on ebay :
                      http://www.ebay.co.uk/itm/2709597472...84.m1423.l2649
                      been looking for info on transformers but couldnt find anything, i checked them all and the primarys were all roughly 1kohm within +-10%
                      when the power comes on it seems like all the bulbs are coming on so i dont think its a bulb out
                        It's difficult to tell if a bulb is out on a TV.
                        But it's rare - most common failure is a transformer or output (fuses, MOSFETs, driver IC...)
                        Are there any fuses on the board, there are sometimes individual ones for each group of inputs, so check these...
                        Also check the buttons on the side/bottom panel are not stuck/jammed as I had the same issue with a Bush, would turn off in seconds sometimes (but thankfully not a Vestel.)
                        • shepp
                          • Mar 2012
                          • 377
                          • England
                          ill have a look tomoro...will the fuses be surface mount ones? ill take some more pics of the invertor boards when i strip it down again tomoz.
                          just had a quick check through the buttons but they seem to work on push testing unless the contact on the boards dodgy but again will check properly tomoro and get back to you
                            Yeah, the fuses will be SMD.
                            I used contact cleaner to fix the Bush - no issues, would recommend spraying a bit in there if you have some spare.
                            You could also unplug the button board to see if it turns off without it plugged in...
                            • shepp
                              • Mar 2012
                              • 377
                              • England
                              invertor master pics
                              all 4 fuses on this board are ok
                                OK check primaries of transformers too all should measure close to zero.
                                • shepp
                                  • Mar 2012
                                  • 377
                                  • England
                                  i checked through the pins and there the only sensible readings im getting on all the transformers, there isnt really any that sticks out as shorted or open
                                    Do you see 0.8 ohm on all the transformers?
                                    • shepp
                                      • Mar 2012
                                      • 377
                                      • England
                                      ye all are below 1ohm but i have just spotted that when ive reconnected one of the bulbs i bent the pin so when i tested it again it did the same come on then went off, so it might be a bulb gone, ive just put the pin back right and retested and its still doing the same, how do i check the bulbs? with the meter? or shall i just disconnect them one by one and see if it stays on?
                                      • shepp
                                        • Mar 2012
                                        • 377
                                        • England
                                        just checked other board, fuses are ok, just gone through the bulbs using the test points and they are all measuring 5.6kohms roughy (within 0.1kohm) on both boards that must be the winding on the transformer tho.
                                        • ItepK
                                          LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
                                          by ItepK
                                          Hello everyone! I've found this television, and I began troubleshooting it.
                                          First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
                                          I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
                                          After the recapping, all the voltages stableized, however, the issue in the title still remains.
                                          I could...
                                          01-03-2025, 09:01 AM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • burbutsalos
                                          55" QLED QE55Q60T Turns on after 1 minute the picture goes bad and get in boot loop
                                          by burbutsalos
                                          Hello ,
                                          The issue with this set is that it turn on just fine and after a minute or so the picture shows either vertical lines or turns half black and from that point on starts a boot loop.
                                          If a let the unit to cool down for a minute the same pattern starts again. i had exactly the same mainboard as a spare and replaced it but nothing changed.
                                          Any ideas what to check?...
                                          12-12-2023, 06:06 AM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
