Olevia 323-s11--badd caps...
    Just bought this tv...not working condition---10$...
    Im replacing some bad caps on it....they were ready to bust....
    i drew a diagram of the caps location on the power supply board and their name and volts....{ you know 1000 uf 10v] stuff like that....
    there were 3 that i couldnt identify...they were acidy and i didnt want to touch them...
    Do you know where i can get the diagram of where the caps are located and where they go...I would so appreciate it...???
    power supply board is *** fsp130-3f01 ***
    Re: Olevia 323-s11--badd caps...
    Writing it here just in case nobody else posts something more useful...
    I suggest searching ebay auctions for one of these, then contacting the seller asking them for the info.
    Also, shopjimmy has one version of the board for sale: http://www.shopjimmy.com/catalogsear...q=fsp+130-3f01 Not sure if they'd have the time to look up those capacitors but who knows, it never hurts to ask.
    You won't really get your hands hurt if you try to clean those capacitors with a bit of water or ipa (isopropyl alcohol) to get the value
      Post pics of the caps in question, clearly focused in. I have a strong feeling your confusing the brown clear glue that they used to hold down parts on these boards. Are you getting any lights on from the tv? did you test any of the voltages leaving the power supply, and test the main fuse to see if its blown?
      Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
        i already removed them...
        but i cant see the number on the caps....
        Their just not readable...its not a glue but a weird red adhesive....
        i can only make out partiall numbers...like 16v and 25v....but nothing else....
        was hoping you might know where to find the manual so i can see whats located in
        cs19
        cs20
        cs21
        22
        23
        24
        25
        28....
          The closest i can find to your manual is
          but that is for 232-s12. It probably is extremly similar though.
          The reason i doubt your caps are bad is because they used a lot of adhesive on these boards, and they were fairly respectable caps on my 232-b11. And multiple people have had issues with the b11 blowing the main fuse after some mosfets short.
            the fuse looked ok....the only thing i didnt change is the biggest cap....the 220v...do you think i should change that,,,???
              Take a reading of the DC voltage across the cap. If i remember correct it was only 168 or so volts on my olevia (olevia must not care about making a high efficiency design). And the fact they chose a 220v cap shows that as well. Its unlikely the primary dc cap is bad though.
              So youve replaced everything now except the primary dc cap? And its still not working?
                We are working blind here we can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                Examples of what is needed
                https://www.badcaps.net/forum/attach...1&d=1290283049
                https://www.badcaps.net/forum/attach...7&d=1280167246
                the fuse looked ok.
                Lots of fuses look ok - did you measure/test it - how many ohms
                should be the same as putting probes together
                  sorry.. for not returning your post....
                  ive been waiting for a camera....mine died....it refuses to turn on.....and smells burnt.....
                  I think my nephews put the wrong adapter in it..and burnt it,,>>>>
                  i found one on craigslist...just waiting for the dude to email me back from a.work trip hes on.......
                  I really do appreciate your time...and dont want to be a jerk and leave you hanging....with out a good reason...
                  so ill post the pics once i get a camera...and hope you or another moderator can help me out...
                    Cool, i cant wait for some good pictures.
                    Also please clarify whether you tested the fuses with a multimeter (i gave you the benefit of the doubt and assumed this), and didnt just visually inspect them.
                      i lost the camera ..so no pics....
                      but you wont believe this...I was replacing the big cap in the middle...
                      a 100uf 400v....and the sauder on the board completely came off....
                      I mean no contacts. points... theres no metal or wire to grab the cap ....
                      im so pissed...IT came off like it was tape....right off the board...
                      im just out of luck and going to just unsauder the new Rubycon caps i put in it....and by a replacement board for it on ebay.....
                      So thanks for your help....i wish this was a success story...i know
                      doit yourselfers like you and me are proud we fix things with a few bucks and know how....
                      but not today....
                      hey.. im working on an Envision h22w that blinks green....thats my next saudering project...if i run into any problems ill post a new thread for help....
                      Thanks again....
                        you could possibly scrape the board to expose the copper around the holes and solder to that point. And since your going to just replace the board it would be worth a shot. Whats there to lose right??
                          thats was my thought after i saw the metal contact point.. sticker off....
                          so i tried it..
                          it didnt work....red power on light didnt even turn on.....Not one sound....
                          ill just have to wait till i order the part....
                          suxxxxxxxx
                            If the traces come off the board your probably using too hot of an iron, or keeping it in contact with the part too long. But this happens to even the best people when soldering.
                            When it happens to me i just run a new small wire from the part to wherever the trace went. Thats much easier then trying to repair the pad, or expose more of the trace.
                            So if that big filter cap's trace runs to the bridge rec m youd just run a wire from the cap to the bridge rec.
                              using a 40w iron..........
                              trace is to close to other caps and sauder points......
                              no real room for me to try...
                                a 40w iron is a little high , if your using it at full temp (or if it has no temp dial / and is always at full blast).
                                Usually 25w at 100% is appropriate for electronics , the tricky thing is if its a big part youll need 60w just to keep it at the right temp > so if you do a lot of electronics work youd want one that has a temperature setting
                                  Thanks again....
                                  I'm working on two of the same monitors - Envision H22W - and I'm stomped at this point. Both are reading the voltages they need to at the test points but nothing but a blinking light still.
                                  However, I've noticed that if I unplug the 9 pin connector from the power supply to the logic board, the backlights light up. Perhaps a switching problem in the power board? Backlights failed to activate on other power boards when I used this same approach.
                                  I'll make some updates to this soon. Capacitors look practically new...no burns...looks new inside in fact.
                                    This thread relates to an Olevia 323 S11 as per the title it was only a passing comment
                                    regarding an envision Please start your own thread in the correct COMPUTER DISPLAYS forum.
                                    If you can go in NOW and edit your post down to "posted in error"
