Tcl pdp42u3h
  • Amraks
    • Nov 2011
    • 725
    Tcl pdp42u3h
    Model: TCL PDP42U3H
    Got this 42" tv plasma giving to me.
    Issues so far.
    1. No remote
    2. Flickery when tv is in white
    would this be a cold solder joint some where as its intermittent
    looking for the manual can't seem to find one any ideas where to look?
    thanks for reading and thanks if you can help me
  • Amraks
    • Nov 2011
    • 725
    Re: Tcl pdp42u3h
    PSU model: n3501q00150a
    I thought I better add in that.
      Re: Tcl pdp42u3h
      Likely bad 450V caps or bad 200-250V caps on primary and secondary respectively.
      • Amraks
        • Nov 2011
        • 725
        Re: Tcl pdp42u3h
        I have fiddled with the v and y sync seems to have fixed it.
        But now I think its the contrast might be set to bright.
        Anyone know of if a harmony remote will work with the set?
        • Amraks
          • Nov 2011
          • 725
          Re: Tcl pdp42u3h
          sometimes I'm getting white lines flicker across the screen is this what these caps do when they go bad. its not very often but I'm thinking its when there is a heap of white being displayed.
            Re: Tcl pdp42u3h
            Never had this fault before, but I think that could cause the problem.
            By the way the PDP42U3H only has an 852x480 resolution - not HD. I can find these for £10 each in working condition.
            • Amraks
              • Nov 2011
              • 725
              Re: Tcl pdp42u3h
              Thats 12 dollars Australian dollars.
              I would near get 150 if I sold it as is but hey I need a flat screen in the lounge room.
              Its probably going to be temporally until I get others come in, then I can probably get rid of it.
              to the guy who thought it was broken because he found it next to the recycling skip bin at his work and it was pulled apart.
              I will look at getting a remote today.
              • tibimakai
                • Jan 2012
                • 3680
                Re: Tcl pdp42u3h
                Go to Logitech and punch in the brand and model number and will let you know if it will work with it.
                  Re: Tcl pdp42u3h
                  Really? That would be nice. Maybe someone dumb would buy it. A 720p 42" would be worth maybe AUD$150, but this is just a 480p. Still, it is plenty nice for games and SD (which most people watch.)
                  • Amraks
                    • Nov 2011
                    • 725
                    Re: Tcl pdp42u3h
                    well basically everything here on tv is nearly SD except for 4 channels.
                    So yeah after watching a vacuum tv I won't notice the difference.
                    Its not a bad tv playing the PS2 on it will be good.
                    • japlytic
                      • Oct 2005
                      • 2086
                      Re: Tcl pdp42u3h
                      If I was a retailer in Australia, I would not sell 480 line flat TVs, since they are primarily intended for NTSC markets such as North America.
                        Re: Tcl pdp42u3h
                        480p is a standard for plasmas, NTSC or PAL. That means in the UK, a 42" plasma has a lower vertical resolution than a 28" CRT.
                        • Amraks
                          • Nov 2011
                          • 725
                          Re: Tcl pdp42u3h
                          Got remote then fixed everything
                          I have been keeping it switched off at the main power all week.
                          Now it has a luminescent green over all the white.
                          also some luminescent blue over some stuff.
                          Anyone got any ideas about where to start?
                          • Amraks
                            • Nov 2011
                            • 725
                            Re: Tcl pdp42u3h
                            Found a schematic.
                            it does it after it heats up, any ideas?
                            • Amraks
                              • Nov 2011
                              • 725
                              Re: Tcl pdp42u3h
                              worked that problem out.
                              Was playing with the screw things in the back of it.
                              and also found the system menu. where you can set the default colors.
                              Now I'm stuck with 1 second flickers.
                              found a better manual
                              http://www.scribd.com/doc/12273298/Tcl-China-Pdp-42u3h
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                Re: Tcl pdp42u3h
                                just fixed up an lg 42" plasma monitor.
                                had interference type patterns,white streaks,black streaks,and flicker.got to poking about with a scope and found all sorts of trash on regulated supplies.had to replace about 60 sm caps.
                                its perfect now.
                                set it up on a pc with dream aquarium screen saver and it sold itself.
                                • Amraks
                                  • Nov 2011
                                  • 725
                                  Re: Tcl pdp42u3h
                                  But I have re calibrated the Vs/Va pots they both equal the required voltage now.
                                  But I do believe one to be going up down 270.0 to 270.2 is this normal?
                                  should it be at a stable 270.0 on my multimeter?
                                  Have I answered my own question?
                                    Re: Tcl pdp42u3h
                                    270 Vs?! Are you sure?
                                    • Amraks
                                      • Nov 2011
                                      • 725
                                      Re: Tcl pdp42u3h
                                      190 Vs
                                      sorry
                                        Re: Tcl pdp42u3h
                                        190 Vs
                                        sorry
                                        Is it stable during flickering? It should be rock solid. 0.1V max variation over full brightness - this voltage is directly proportional to picture brightness.
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • Zippo978
                                          Telefunken te43550b40q2k intermittent backlight
                                          by Zippo978
                                          Good morning everyone
                                          I have this Telefunken te43550b40q2k TV that has intermittent backlighting, sometimes it turns on and then does not turn back on.
                                          I tested the LED bars and all three work, not even one burned LED, then I tried to put only two bars short-circuiting the end of the connection cable and it does not give any problem the LEDs stay on without problems, I also tried short-circuiting the central connector and the initial one, always no problem, but as soon as I put the third bar, no matter the position the problems start again.
                                          Thanks in advance...
                                          09-04-2024, 01:35 AM
                                        • BigPete
                                          Intermittent display on Sherwood Newcastle R-965 Receiver
                                          by BigPete
                                          I'm working on a Sherwood R-965 at the moment. It came in with relays clicking constantly and also going into protect mode.
                                          I've re-soldered a lot of dry joints and replaced quite a few capacitors and now it works, but I still have one problem I haven't solved and would like some opinions.
                                          The vacuum display is quite intermittent. Sometimes it won't turn on, sometimes it will turn on but the characters, numbers and letters are frozen on, regardless of which buttons are pushed. And sometimes it works flawlessly. If the display doesn't turn on initially, restarting...
                                          08-25-2024, 02:48 AM
                                        • themosttogain
                                          HP Envy 13-BA1565na with intermittent power button
                                          by themosttogain
                                          Hope someone can give me some suggestions on this because i'm at my wits end with it...
                                          I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                                          Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                                          07-12-2024, 03:03 AM
                                        • proxneo
                                          Bose Wave I AWRCC1 - intermittent to no sound output - loud popping & crackle sounds
                                          by proxneo
                                          Dear reader
                                          I have been asked to check out a faulty Bose Wave system belonging to a relative. The faulty unit produces loud intermittent pops and crackles. Sometimes there is speaker audio output (FM/AM, CD etc.), most of the time there isn't. This behaviour degraded over time fairly quickly, to the current situation where no sound is put out at all. Gently messing and wiggling wires, connectors or heatsink has no effect in force-replicating the problem. I have little experience in audio repair when it comes to (main)board electronic component faults. Bose repair WAS about 140$ (most...
                                          12-02-2023, 09:27 AM
