Monitor Samsung SyncMaster 206BW
  • starter28
    • Sep 2010
    • 5
    • Poland
    I welcome,
    I am calling for help.
    The display type: M201EW02 V.8
    I am thanking for help.
    Bad capacitors C228.
    What value he should have C228?
  • tibimakai
    • Jan 2012
    • 3680
    Re: Monitor Samsung SyncMaster 206BW
    maybe you should check the datasheet for that small IC.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      DOUBLE THREAD - Please do not do that. I have responed on the other
      Default Re: Proview LB 2006 W Monitor
      @starter 28
      Hi= this Tcon has a different layout than that in the thread, is it out of the same make of monitor? Can we ask why you need to know -is it missing , shorted or what.
      As you are new and have not posted the New members forum we have no idea of your level of knowledge. Are you aware that there is fuse/s on these boards and have you checked it/them.
      I believe you will not get an answer to your question as this detail is rarely known most people seem to just try and find a cap the same size and shape and put that in. Finally perhaps you could update your profile with Country and Home Mains Voltage in case your post goes on.
      • starter28
        • Sep 2010
        • 5
        • Poland
        This C228 is doing the short circuit.
        I don't have from where from to take so, I don't have other monitor.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Doesnt have to be off a monitor look in any faulty electronics.
          Electronic repair shop in Warsaw? should not be more than 1 Zloty.
          You will need to take it off so they can see the size.
          See Ebay for idea of prices.
          • starter28
            • Sep 2010
            • 5
            • Poland
            In servisie they told Eeee it was a memory she sat down, I reached that the short circuit was on T-con, the short circuit is doing C228.
            And I can put which for the inspection? 10uF ?
              09-07-2024, 05:50 AM
              by momaka
              03-15-2023, 10:17 PM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
