Can anyone help me with obtaining a service manual for a LN40B500P3F samsung tv? Thank you!
samsung LN40B500P3F
Re: samsung LN40B500P3F
I just got one of these. Mine won't turn on but I do have stby5.3v on psu. Also tested 13v from 3 leads and 5.3v from 2 leads on con 29/30
My first guess is the tuner card is bad since everything runs through there.
The Guy said a lightning strike took it out.Attached Filesif you find these attachements useful please consider making a small donation to the site
Does the backlight come on when you unplug that ribbon cable from the inverter/power supply board? Inverter ON/OFF pin should have >3V same for PWR ON/OFF PIN when TV is turn on. Your DC readings are OK.Last edited by budm; 10-18-2012, 02:00 PM.Never stop learning
This is a Black Friday special, a variant of the LN40B530 I believe.
Uploaded manuals here:
http://tgohome.com/ServiceManuals/?d...&Search=Submit
Please note, there are at least two variants of this chassis, N70A and N64B. Check the model code precisely for the right variant.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Your power supply/inverter board is OK, you will have to troubleshoot the main board next, the inverter ON/OFF signal from the main board is not working, it is stuck in the LOW (Off) mode.Last edited by budm; 10-18-2012, 02:45 PM.Never stop learning
model code is
LN40B500P3FXZA
I guess i dont see the manual or its not there
here is a closeup of main board if that helps. I dont know if theres much i can do but the only main board i could find was $90 so hopefully i can fix it with your help.
main board is BN94-02746KAttached Filesif you find these attachements useful please consider making a small donation to the site
Wow, tiny main board.
Check the manuals I linked to, they are B530, but they might be the same.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
maybe im too tired. i understand the test process for main board i think but the test points dont seem labeled the same as the manuals. all the test points i see are marked TP*** (3 digit numbers)
if im going to figure out whats wrong i need to be walked through this one. smallest board i have attempted to fix and i dont know what half the parts are on it lol.....Comment
http://www.populargaragesale.com/pgs...product_id=747 - Says not working? Or maybe untested?
http://www.ebay.com/itm/SAMSUNG-LN46...-/200828359389 - Insane price!
http://www.ebay.com/itm/SAMSUNG-LN46...-/200828359389 - Same part from Emerson TV?Last edited by tom66; 10-19-2012, 01:54 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
You can contact Shopjimmy to see when he will have them instock again:
http://www.shopjimmy.com/catalogsear...ng+ln40b500p3fNever stop learning
I contacted shopjimmy they couldn't say whenor if they would restock.
I also contacted samsung support. They knew less than me. They were unaware of any replacment but shopjimmy says either bn94-02746k or bn94-02746y will work.
Unfortunatly I cannot find either in stock for less than $90+shipping used and I forgot where I found it. LolLast edited by ryan74; 10-19-2012, 01:07 PM.Comment
The transistor on the main board is on so the output will be low (the transistor may be told to be on due the bad processor or bad transistor), the pull up resistor is in the power supply board thst is why when you remove the cable to the main board, the power supply and the backlights turn on due to the pull up resistors on the power supply board are pulling the pin high.
What we need to do is to find out next if the only circuit that is bad is the Inverter ON signal or it may have more than one problem. Waht you can do is to disconnect the Inverter on wire only for the the board so the backlights will come, if everything else is OK, hten you should be able to see the pictures and sound from the TV. If not, then you have multiple problems with the main board. The whole purpose of the backlights is to give the light source so you can see pictures, it does nothing else, so try that.Never stop learning
You can cut the wire then you can splice it back together when we fix other problem, just make sure to cut the right on and also tape up the ends.Never stop learning
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 06:20 PM
- Loading...
