samsung LN40B500P3F
  • kueberco
    • Mar 2012
    • 66
    • usa
    samsung LN40B500P3F
    Can anyone help me with obtaining a service manual for a LN40B500P3F samsung tv? Thank you!
  • ryan74
    • Oct 2012
    • 471
    • usa
    Re: samsung LN40B500P3F
    I just got one of these. Mine won't turn on but I do have stby5.3v on psu. Also tested 13v from 3 leads and 5.3v from 2 leads on con 29/30
    My first guess is the tuner card is bad since everything runs through there.
    The Guy said a lightning strike took it out.
      Does the backlight come on when you unplug that ribbon cable from the inverter/power supply board? Inverter ON/OFF pin should have >3V same for PWR ON/OFF PIN when TV is turn on. Your DC readings are OK.
      • ryan74
        • Oct 2012
        • 471
        • usa
        yes the backlight came on when i disconnected the ribbon from psu.
        i reconnected it and checked
        pwr on/off 1.17v
        inv on/off .09v
        i assume these are low because it wont turn on yet?
          This is a Black Friday special, a variant of the LN40B530 I believe.
          Uploaded manuals here:
          http://tgohome.com/ServiceManuals/?d...&Search=Submit
          Please note, there are at least two variants of this chassis, N70A and N64B. Check the model code precisely for the right variant.
            Your power supply/inverter board is OK, you will have to troubleshoot the main board next, the inverter ON/OFF signal from the main board is not working, it is stuck in the LOW (Off) mode.
            • ryan74
              • Oct 2012
              • 471
              • usa
              model code is
              LN40B500P3FXZA
              I guess i dont see the manual or its not there
              here is a closeup of main board if that helps. I dont know if theres much i can do but the only main board i could find was $90 so hopefully i can fix it with your help.
              main board is BN94-02746K
                Wow, tiny main board.
                Check the manuals I linked to, they are B530, but they might be the same.
                • ryan74
                  • Oct 2012
                  • 471
                  • usa
                  maybe im too tired. i understand the test process for main board i think but the test points dont seem labeled the same as the manuals. all the test points i see are marked TP*** (3 digit numbers)
                  if im going to figure out whats wrong i need to be walked through this one. smallest board i have attempted to fix and i dont know what half the parts are on it lol.....
                  • ryan74
                    • Oct 2012
                    • 471
                    • usa
                    anyone have a main board for samsung ln40b500p3f
                    board number is: bn94-02746k (alternate bn94-02746y)
                      http://www.populargaragesale.com/pgs...product_id=747 - Says not working? Or maybe untested?
                      http://www.ebay.com/itm/SAMSUNG-LN46...-/200828359389 - Insane price!
                      http://www.ebay.com/itm/SAMSUNG-LN46...-/200828359389 - Same part from Emerson TV?
                      • ryan74
                        • Oct 2012
                        • 471
                        • usa
                        The links you posted look like the right part but numbers don't match. Are you sure, these are compatible.
                          I am not sure at all when it comes to Samsung and board compatibility, it's not obvious.
                            You can contact Shopjimmy to see when he will have them instock again:
                            http://www.shopjimmy.com/catalogsear...ng+ln40b500p3f
                            • ryan74
                              • Oct 2012
                              • 471
                              • usa
                              I contacted shopjimmy they couldn't say whenor if they would restock.
                              I also contacted samsung support. They knew less than me. They were unaware of any replacment but shopjimmy says either bn94-02746k or bn94-02746y will work.
                              Unfortunatly I cannot find either in stock for less than $90+shipping used and I forgot where I found it. Lol
                              • ryan74
                                • Oct 2012
                                • 471
                                • usa
                                So if it is stuck in low mode can you help me troubleshoot/test this?
                                • gilly1984
                                  • 751
                                  Is it possible to force a few volts into it to test it?
                                  Do NOT touch heatsinks when testing for voltages as they may be LIVE!
                                    The transistor on the main board is on so the output will be low (the transistor may be told to be on due the bad processor or bad transistor), the pull up resistor is in the power supply board thst is why when you remove the cable to the main board, the power supply and the backlights turn on due to the pull up resistors on the power supply board are pulling the pin high.
                                    What we need to do is to find out next if the only circuit that is bad is the Inverter ON signal or it may have more than one problem. Waht you can do is to disconnect the Inverter on wire only for the the board so the backlights will come, if everything else is OK, hten you should be able to see the pictures and sound from the TV. If not, then you have multiple problems with the main board. The whole purpose of the backlights is to give the light source so you can see pictures, it does nothing else, so try that.
                                    • ryan74
                                      • Oct 2012
                                      • 471
                                      • usa
                                      added a few more pics above
                                        You can cut the wire then you can splice it back together when we fix other problem, just make sure to cut the right on and also tape up the ends.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
