pioneer plasma PDP-435PE
  • sienoki
    replied
    Re: pioneer plasma PDP-435PE
    Originally posted by Jasgriff
    Panasonic GT Series are still made by the old Pioneer chappies!
    How long will gases last for screen with it been 2005 model?
    Its a very nice looking setup shame freeview not built in to MR box..What sort of money do these go for in used cond..im thinking of making him an offer as its better looking than my nearly fixed LG 42"
  • Jasgriff
    replied
    replied
    They *made* nice plasma TVs... they don't any more. Shame.
  • Jasgriff
    replied
    Well happy that you have got it going!
    Pioneer make mint TV's. Just need to give it a clean up in side and it will be like new
  • sienoki
    replied
    Originally posted by sienoki
    Well ive took dog for a walk & to clear my head cos this set done my head in so far..ive stripped remote down & cleaned with isproponal..plugged everything back together & tried the remote sequence again & BINGO it fired right up
    Once in the service mode i dont want to mess any settings up so i set time n date & left it at that...it dosnt have freeview built in so trying with a cheapy 1..I want to do a full factory restore to the set & could do with..thx
    Ive sussed it out..what i did if any1 ever comes across this problem..
    to enter service mode press display button wait 3secs then left arrow/up arrow/left arrow/right arrow then power button..then in service mode keep pressing mute button till you get to initialize page..then press & hold the display button untill the red led goes out from the MR..
    Thx guys n gals for your feedback & help
  • sienoki
    replied
    Better pics of them diodes..also this card thats soldered in has a orange led lit when the set is on..thx..its the card behind the heatsink
    Them diodes are measuring good out of circuit
  • sienoki
    replied
    Looks like tipex..when probing diodes etc on this tv psu there is 2 diodes D24&D26 which both measure .032 with a continues beep on diode check function..will i need to pull a leg to retest as all the other diodes measure a reading & OL..thx
  • sienoki
    replied
    Will open it back up & get jewel eye out
  • sienoki
    replied
    Originally posted by tom66
    What's up with that 4 pin black chip with a mark on it, top right of picture? It looks like an optocoupler but the marking on it looks like damage.
    replied
  • sienoki
    replied
    Originally posted by cadiman
    If the signal cable is unplugged the tv should have an orange light and it may flash.
    The media boxes with these held up very well and I would suspect the small round signal cable first before taking anything apart.
    look for bent pins. also this cable has the audio signals as well.
    I have the 50hdt50m version of this tv made by pioneer for Hitachi (2003) with the updated power supply. I would not trade it for anything!
    Find out if the tv power supply is an axy-1059. The updated version is an axx-1064 and will be tagged on the aluminum back of the power supply.
    Your tv may vary slightly from mine pending the year. There were a few different models that used the media boxes.
    Hi cadiman..theres now bent pins on either of the lead ends..heres a pic of tv psu model no..with the tv disconnected from the MR the leds on tv green & red flash together indicating MR unplugged..with the MR plugged in the tv led is red flashing 2 times indicating a problem with MR..all you get from the MR is both power on & standby led both been on together..thx
  • cadiman
    replied
  • sienoki
    replied
    What is the trap switch? I would think it is actually illegal in many cases for a manufacturer to disable a product if the case is opened unless there is a justified reason e.g. a credit card terminal (anti-tamper), medical device... At the very least, it doesn't make sense: why would they produce a service manual then?!
    The trap switch is tripped when the top panel is taken off & if powered on with lid off it disables the MR..when servicing the unit your supposed to tape it down..its not illegal from what ive read its an anti tamper device..something pioneer developed...allot of tv techs are stumped on this when the remote sequence does not work..so i guess im trulely stumped unless any 1 here likes a challenge..anyways fingers crossed this dvi ti hdmi might shed some light..thx
    replied
    Hi tom..no harddrive or flash memory fella..will leave the set till cable arrives..have you ever come across this trap switch before?..all info on tinternet applies to remote sequence tried this & no good..1 tv tech said solid red & green & MR in some shut down mode??anyways thx 4 info so far mucka
  • sienoki
    replied
    Not necessarily... There are three signals there and at least two are important. One is PD Trigger, the other is AC Detect. PD Trigger makes me thing of a signal that fires when the power supply is about to power down. (Does the box have a HDD or flash memory?) AC Detect performs a similar function.
    I would wait for the DVI cable and then if you get a good display I think you can rule out the media box.
    replied
    Without the ac detect & the standby voltages the other voltages needed wouldnt be present..so because all the voltages are correct on the main pin out im presuming the psu is in working order & the fault maybe lies elswhere in the mr box..am i correct in assuming this?..thx
  • sienoki
    replied
    Ive ordered that cable..thx
  • sienoki
    replied
  • sienoki
    replied
    Good. Now what does it say about AC detect? Does it seem right?
    (I'm trying to get you to do this yourself, so you learn a bit about the process.)
    I will read over the service manual & see if i can learn owt..thx
    replied
    Ive no other tv available to try dvi cable..all ive got is hdmi ports on other tvs
    HDMI to DVI cable?
    http://www.ebay.co.uk/itm/1-5M-GOLD-...#ht_1922wt_956
  • RatherLoopy
    Pioneer VSX-44 receiver HDMI dropouts
    by RatherLoopy
    I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
    I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
    And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
    05-26-2023, 03:54 PM
  • pixelcap
    Pioneer Plasma 111FD To Solder or Not to Solder.
    by pixelcap
    Hello out there in Badcap land.
    I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
    are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
    Thank you
    Pixelcap...
    03-08-2025, 07:10 PM
  • pulper111
    Pioneer VSX-1123 Receiver - weird voltage problem
    by pulper111
    Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
    I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
    09-02-2020, 11:12 AM
  • thetonywarren
    Pioneer VSX-3300 Receiver Wont Power On
    by thetonywarren
    Have a colleagues Pioneer VSX-3300, it wont power on, hasnt for a number of years, but just now trying to figure out what's going on with it.
    It has 120V input and I have followed that 120V to a small board that appears to have a small transformer and a relay among a few other components I dont think the relay is changing state which I believe turns on the receiver, but this is all speculation.....
    I have downloaded the repair guide, which I have attached to this post, but I am having a hard time following it.... Can someone please offer any advice on what to check?...
    12-28-2021, 01:26 PM
  • wolf1976
    wireless receiver for 6 speeds fan control with remote control
    by wolf1976
    hi i have a receiver that is destroyed from the overvoltage i guess
    my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
    the motor fan has not label
    i have an other receiver operational
    In your opinion can i measure the voltage at the output ?
    what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
    thanks in advance...
    07-23-2025, 03:12 PM
