Need some help finding this part
  • sienoki
    sienoki
    • Jan 2012
    • 314
    Hi guys n gals..a friend has given me a LCD400f1080p ACOUSTIC SOLUTIONS.
    The inverter board SSI400WA16 has a black connection strip that clips onto the ends of the backlight bulbs..this part is badly corroded and i need a replacement..but cant find any info anywhere..any ideas???..thx
    The screen is a Samsung LTA400HT-L03
    Now found its a LJ61-02492A SAMSUNG LAMP HOLDER but dont trust any old place on google..any recomendations??
    Theres only 1 place on google i can find its in the US
    ELECTRONIC COMPONENT TRADERS
    2171 SW 24 TERRACE
    MIAMI, FLORIDA 33145
    Has any of you guys had any dealings with this company..thx
  • sienoki
    sienoki
    • Jan 2012
    • 314
    Re: Need some help finding this part
    2171 SW 24 TERRACE
    Before i try and order this part i could do with as when i powered this set up backlight lit up for 2 seconds then off..i noticed several lines from top to bottom on screen..dead pixels??so i stripped it down further to notice the LVDS wires where out of the plastic casing..so my question is can a bad LVDS cable produce horizontal aswell as vertical??
    • sienoki
      sienoki
      • Jan 2012
      • 314
      Some pics of the badly burned corroded part
      http://s1068.photobucket.com/albums/...t=P1000930.jpg
      http://s1068.photobucket.com/albums/...t=P1000931.jpg
      http://s1068.photobucket.com/albums/...t=P1000932.jpg
      Before ordering the new part i was wondering if i could solder some thick wire to the ends of the tubes and onto the inverter board..good or bad idea??i dont want to waste money on new part if the panel is bad..any thoughts??
        master hoarder
        • May 2008
        • 12170
        You could do that, but you will need some high voltage wire, preferably rated for 2 KV or more.
        You can also use different (and more standard) connectors as well, but then you will also have to replace the connectors on the CCFL tubes.
        As for the vertical lines on the screen, I'm not sure about that. Could be just dirty contacts on the LVDS connector or could also be a bad panel (i.e. ripped ribbon cable between t-con and panel).
        It might be better to start with the backlight first, though. Retiredcaps has written an article on how to troubleshoot 2-seconds-to-black problems. You can find it here:
        https://www.badcaps.net/forum/showth...+seconds+black
        • uberplasma
          • Oct 2011
          • 85
          those pics look like a peavey amp - lol
          I have replaced most of the conectors with straight solder connections in any peavey I come across, nowhere near the same voltages going through them, but always works.
          if it is your TV(or if it was mine) I would do it in a heart beat, only problem is the wires may be tight and it will be permanent and could cause some service problems if you ever needed to get that board out of the way in the future. remember - nice shiny joints - lol
          • edugimeno
            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
            by edugimeno
            Hi There!
            I'm trying to help my friend who owns a restaurant be just bought.
            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
            It's stuck using, I guess, the 2 sided tape that comes with the strip
            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
            09-05-2024, 09:34 AM
          • G-Sting
            iPad Pro A1876 SHORT Part Identify Help Needed
            by G-Sting
            So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
            So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
            i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
            SO My main concern is what part should i order what should i search the name for ?
            on Ipad...
            05-15-2025, 09:30 AM
          • Yanleb
            Panasonic part number in service manuals
            by Yanleb
            In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
            This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
            For an example, look at the attached PDF.
            Do you have a way to cross reference the Panasonic part number with the actual part number?
            Thanks....
            07-03-2023, 08:16 PM
          • FreakyMex
            Trouble to identify part (Lunii screen) for replacement
            by FreakyMex
            Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
            I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
            02-17-2025, 01:16 AM
          • esinior
            Smd code to part number
            by esinior
            Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
            I've attached pics of this part
            Thanks...
            08-20-2024, 02:50 AM
