SONY AVD K800P receiver plays CD's Not DND
  • DIODE
    • Mar 2012
    • 30
    I have a Sony AVD K800P CD/DVD receiver/player that will play CD's (after reading for extended period) but will not play DVD, costs $14 at community Thrift store so no big deal, but would like to get the DVD to play. I've tried the CD "cleaning disk" that seem to make no diference at all , have not opened it yet, it's semi-permentelt mounted under a shelf (I know ....I should have completely tested before installing) I've seen online references to laser power adjustments that seemd to fix for others with similar problems. Anyone seen this before and got it fixed?
    Dan
    Last edited by DIODE; 03-09-2012, 05:08 PM. Reason: Should have read "DVD" not "DND"
    master hoarder
    • May 2008
    • 12175
    Re: SONY AVD K800P receiver plays CD's Not DND
    Laser diodes get weaker from use. In this case, the DVD laser was probably used more than the CD laser, hence why the DVD stopped reading.
    You can adjust the power to the laser (there's usually a potentiometer on the laser assembly for that), but that is only a temporary fix because the extra power you give to the laser will just make it go weak faster.
    The best option would be to replace either the whole laser assembly (provided you can even find one for your model) or just replace the DVD laser diode. I've never done the latter, so I'm not sure on the specifics regarding adjustments on that.
    • sretchko
      Sony Receiver STR-4800SD L/R Balance
      by sretchko
      Hey fellow solder fume lovers, I have a Vintage Sony Receiver STR-4800 SD that has me stumped.
      The Balance Pot has to be set at about 30 degrees (11 o'clock) to the left for the output to be balanced (see photo). I'm using an oscope, sig gen 1kHz sine, 8 ohm dummy load).
      When output is balanced (11 o'clock left) both channels clip at about 19 vac / 45 watts RMS, Amp is rated at 35 watts so I know the amp modules are good. Square wave also looks good when turning bass & treble pots and is in phase.
      I pulled the balance pot, (Dual 10K MN Taper) cleaned with...
      Badcaps Electronics Repair Forum & Schematic Search
      04-17-2024, 06:02 AM
    • Carlos#2003%
      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
      by Carlos#2003%
      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
      02-15-2024, 07:52 PM
    • erickeri1234
      Sony str-dn850 home receiver no left channel.
      by erickeri1234
      Ok start off by saying I have some tv repair but not much on the receiver end.
      Picked up a Sony str-dn850 home receiver when I first plugged it in powered it up it came on and the system check relay clicked and about 3 seconds later it went into protection mode.
      I powered it off and on. Comes on no problem.
      Hooked up speakers and it started to pop and crackle but the volume was all the way down.. and I was only getting that sound out of the left channel. Right channel had no sound.. but every time I turn the volume up it has a smell crackling sound on ever volume number......
      10-04-2021, 07:45 PM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-06-2024, 05:27 AM
