Samsung vertical lines
  • tibimakai
    • Jan 2012
    • 3680
    Just a question about this issue.
    I'm thinking about picking up this TV, but before that I would like the pro's opinion from this forum.
    Here is a video of the problem:
    http://www.youtube.com/watch?v=gPis4...eature=related
    It could be a T-con problem?
    Re: Samsung vertical lines
    Very likely to be T-con. It would most likely be a board swap rather than a component fix, though.
    • Falki
      Colorful LCD Vertical Lines on Samsung ue55es8090
      by Falki
      Hello there, ive recently found an older 55inch Samsung SmartTV.
      Sadly it has vertical lines at the left and one line in the middle-right.
      I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
      I have factory resetted the TV as well but also with no luck.
      I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
      A similar issue has been posted as well but also with no actual response ...
      08-12-2025, 04:19 AM
    • Stanley1843
      Screen Display Vertical Multicolor Lines
      by Stanley1843
      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
      06-29-2024, 11:54 AM
    • pni
      LG 49uf695v vertical coloured lines
      by pni
      Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
      11-14-2025, 03:15 AM
    • x_orange90_x
      Samsung UN46C8000XFXZA vertical bars/horizontal lines
      by x_orange90_x
      I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
      The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
      09-04-2023, 12:09 PM
    • polaro
      Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
      by polaro
      Greetings,
      I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
      08-27-2022, 08:46 AM
