Sanyo DP46849 No Image
  • Hearse
    • May 2007
    • 10
    I have a Sanyo DP46849 that I recently got from a buddy that replaced it when it stopped working. When I FIRST plugged it in, the image came up and displayed for a minute and then now, when you turn it on, the GREEN LED turns on but thats it. Nothing else. The problem seems similar to this post, but there was no fix... Visually the Caps appear ok. I have a DMM what/where should I test?
    The pictures are the highest RES I can do with my camera. If you need closer pics of certain areas I can try that.
    https://www.badcaps.net/forum/showth...=Sanyo+DP46849
    Re: Sanyo DP46849 No Image
    We need a good closed up of the connector so we can read the voltage labels on those pins, take pictures at both top and bottom of the board. Right now the standby power supply is working. We are looking for the pin that is labeled with PS_ON, or PWR_ON.
    • Hearse
      • May 2007
      • 10
      Thanks for the reply. There is a PS_ON/OFF, its the bottom pin on the connector. Here are pics with and without flash.
      Its giving me an error with the manage attachments, I put them on photobucket for now.
        Thanks, see waht I can do.
        Please post the pictures using attachment function in the "GO ADVANCED" button. instead of pasting.
          Sorry I did not read your comment about the error, so look and see if you have 3.3~5vdc on that PS ON pin. You may want to read my guide to get some basic ideas also.
          • retiredcaps
            • Apr 2010
            • 9271
            See my sig file below for the site forum picture restrictions.
            I prefer that you do not post inline for many reasons. After 5,000 posts of helping others, it matters.
            --- begin sig file ---
            --- end sig file ---
            • Hearse
              • May 2007
              • 10
              I'm getting no voltage on the PS_ON
              I edited it, I didn't even think about the size restriction, I took the pics in my 1st post with the same camera, some how the resolution changed. Sorry, I edited the original
              • retiredcaps
                • Apr 2010
                • 9271
                Is this with you trying to turn the TV on/off? If not, try pressing the power on/off button to see if the voltage changes.
                Thank you. It is appreciated.
                Now we need a clear picture of the main board.
                • Hearse
                  • May 2007
                  • 10
                  Actually, I just went back to my work bench to take the pics, I guess I left the power button pushed... The TV is working, no joke. I just hooked a PS3 to it and its playing a bluray for about 5 mins now. Maybe I just had a lose wire. I will let it play for a while before I confirm its "fixed"
                  • Hearse
                    • May 2007
                    • 10
                    TV is still going, I turned it off and back on, everything seems ok right now...
                      Well, at least now you know which signal to look for when it stops working again. You may want to take some voltage readings so you will have something to compare with when it stops working.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Is the sequel any good? I bought the first one on blu-ray when it went on sale.
                        • Hearse
                          • May 2007
                          • 10
                          Turned it on this morning, still acting "normal" What voltages should I test just for references?
                          The sequel is decent (thats on netflix) I liked the 1st one better, personally.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            I would get the readings for every pin on CN2 and CN7.
                            • electronicsurplus
                              • 210
                              Hello all
                              I have the same exact problem except mine did not start working : (
                              any help would be appreciated at all
                              Jon
                              This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                              Help keep these from the landfills
                              • electronicsurplus
                                • 210
                                When I press the power button the green light comes on for a few seconds then turns off
                                • electronicsurplus
                                  • 210
                                  Checked the fuse and it is good
                                  No 5v at all
                                    Please post the pictures of your power supply board, and closed up pictures of the connectors so we can tell you which pin to check first.
                                    You can read my basic guide also.
                                    We need to do some basic Voltage checking first.
                                    • electronicsurplus
                                      • 210
                                      Ok, Thank you Bud
                                      • electronicsurplus
                                        • 210
                                        A little closer
                                        My camera is not too good
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 10:56 AM
                                          HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
