I have a VIZIO VO420E that has a very odd problem. When it first comes on most of the pixels on the right two inches or so are black, followed by waves and both vertical and horizontal lines that vary rapidly. Once in a blue moon all the pixels come on for a few seconds. Never seen anything like it. Main board, T-con, or panel? Thanks!
VIZIO VO420E moving waves of black pixels
Tags: None
Re: VIZIO VO420E moving waves of black pixels
Sounds like the panel.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Assuming...7 Photos -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by TbfmHi all.
I bought this LCD TV back in 2008 new and has worked and looked awesome since day one until about 8 months ago when these moving green and magenta dots started showing up that would move with the picture displayed seemingly with certain displayed colours often with whites.
The pixels appear in the system menu displays so I am certain that its not any kind of faulty cables or bad hdmi, and also removed/reseated and cleaned the LVDS cable with no change.
I have looked all over Badcaps and the internet in general for people with similar issues...04-20-2022, 05:13 PM -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... - Loading...
