PHILIPS 50PFP5332D/37 Sound No Picture
    I have a PHILIPS 50PFP5332D/37 that will play sound no picture I pulled it a part seen a couple bad caps I found a couple that look bulged and tested bad with my esr meter so I replaced them still same thing comes on you can hear click then you here another click the led on the power board will blink once then pause blink again then repeat. I tested the vs leads got 215 VDC then tested the vs got 61VDC unhooked the vs connector stays powered up plug it in goes through the cycle of the blinks
    Any ideas if so thank yo
    Gordon
    Re: PHILIPS 50PFP5332D/37 Sound No Picture
    No ideas ???? I would like to get this tv fixed pls
      Do you hear any buzzing from either sustain board?
        no buzzing
          here is the csm.txt
          1.3. Set type : 50PFP5332D/37
          1.4. Production code : YA1A0710003404
          1.5. Code 1 : 04 46 00 00 00
          1.6. Code 2 : 00 00 00 00 00
          1.7. Options 1 : 02064 00292 00549 02691
          1.8. Options 2 : 01109 00000 21024 00000
          1.13. 12NC SSB : 32805531032108
          1.14. Installed date : 01/01/1996
          2.2. Pixel Plus : On
          2.4. DNR : Medium
          2.5. Noise figure : 0
          3.1. Headphone volume : 30
          3.2. Dolby : Off
          3.3. Surround mode : Virtual Dolby Surround
          3.4. Centre input : Off
          3.5. Audio system : Mono
          3.6. AVL : On
          3.7. Delta volume : 0
          4.1. Preset lock : Unlocked
          4.3. Lock after : Off
          4.6. TV ratings lock : None
          4.7. Movie ratings lock : None
          4.8. V-Chip TV status : None
          4.9. V-Chip movie status : None
          4.10. Region rating status (RRT) : Off
          4.12. Table channel changed : No
          5.1. On timer : Off
          5.2. Location : Home
          6.1. HDMI key validity : Valid
          6.2. IEEE key validity : Invalid
          6.3. POD key validity : Invalid
          7.2. TV system : M
          7.3. Source : Tuner,Video
          7.4. Tuned bit : No
          7.6. Digital signal modulation :
          8.1. 12NC one zip SW : 3139 127 09726
          8.2. Initial main SW : EJ30U_0.77.1.0
          8.3. Current main SW : EJ30U_0.81.8.1
          8.5. Flash utils SW : EJ30U_0.77.1.0
          8.6. Standby SW : STDBY_3.0.1.37
          8.7. MOP SW :
          8.8. Pacific 3 Flash SW :
          8.11. NVM version : EJ30U_0.0.0.5
            I have a question, not sure if this is the right place cuz I am a newbie.
            I have this TV in this post above. 50pfp5332d/37 and I accedientially ripped the hdmi connetors off the back of the SSB board. Now i went to look for a new board for the original number 3104 313 61731 and replaced it with a 3104 313 61734 board figuring it was simply a newer model board?
            I reprogrammed the SSB to my options code and screen diversity but still I have NO HDMI input and or when I plug my pc into the HDMI it is not recognized? I plug the pc into the other TV and it is recognized.
            Do I have a BAD BOARD or do I have the Wrong BOARD. This new board sure does seem like everything works but the HDMI Inputs. Is there something else I should try?
            Option Code
            02064 00292
            00549 02691
            01109 00000
            21152 00000
            Screen diversity 085
