My Vizio VX32L HDTV10A is no longer turning on. The logo is amber and power switch does nothing. I have the cover off and verified that the 5 VDC is present. The PWR switch does not make it to the PSON on J1 Pin 1. Anyone know the path of this signal or what the common failure part is? I have also verified that 3.3 VDC is present.
Vizio VX32L HDTV10A not turning on
Tags: None
Re: Vizio VX32L HDTV10A not turning on
Search for vw32l service manual. Follow the DC-DC regulator diagnosis path in the manual. Most people have problems with U33, but when U33 goes bad it will still change the light from amber to white when you press the power button. Perhaps check the fuses on the button board, as well as any regulators on the button board, or around where it connects to the main board.Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by pedromvuHi, I know these TVs are common to have problems like this, but unfortunately I was not able to find repair guide for this specific model or for something with this kind of power board.
The thing is this doesn't have the 5vsb pin which is used to determine from which board the issue comes.
Everything in power and main board was inspected without any apparent problems, but haven't measured everything.
The voltages from Power to Main board are as follows:
NC = 0
A = 0
BL_on/off = (Some millivolts, probably considered 0)... -
Assuming...7 Photos -
by howardc64Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot.... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... - Loading...
