42PF7320A\37 Strange problems...
  • badwr2002
    • Feb 2012
    I was recently given a Philips 42 inch plasma model number 42PF7320A\37, after the previous owner replaced the power supply, and it still had the same problem. The TV would come on, as soon as its plugged in, which I dont think is normal. It would then stay on for about 20 minutes, then it would turn off, and turn back on, stay on for a few more minutes, then shut off, and back on, this time doing it over and over as soon as it comes on until unplugged. It also has a little distortion on the screen just before a reset. Well I decided to check the error buffer per the manual, and it was full of 00's. So I decided to leave the TV alone, and let it go off and on until I got a red light flashing, or an error code. After about 3 hours of hearing this thing click and still nothing im lost. It sounds like a bad solder joint, or a component overheating, but the only chip that is pretty hot at the time of shut off is just below the 2 ribbon cables on the Small Signal Board. I have tried unplugging each board from the power supply, same problem with each. It comes on, works perfect for a few minutes, then goes into a reboot cycle. Any ideas? I can post pictures/video of the TV doing what it does if needed...
    Edit: I should probably add, there are no swollen caps, no burnt spots on the boards, no funny smells.
  • PlainBill
    • Feb 2009
    • 7034
    Re: 42PF7320A\37 Strange problems...
    You are correct - turning on as soon as it is plugged in is unusual, but there is one possible test for that. Once it has been on for a few minutes turn if off and unplug it. Wait a minute or two, then plug it in again. If it doesn't turn on until the power button is pressed, it was 'remembering' the last state before it was unplugged and returning to it.
    The description sounds like a thermal problem. If it wasn't for the video distortion I would suggest just replacing the Small Signal Board - one is available on eBay for $40 shipped. As a test, try forced cooling (or freeze spray) on the chip on the SSB that gets hot. Also check all the voltages on the SSB.
    There is the possibility that the problem is the buffers. I have two of these, they are great sets, but if the buffers / Y-main goes they aren't worth repairing.
    PlainBill
    • badwr2002
      • Feb 2012
      Ah, seems you are correct on the powering on issue. If I turn it off, unplug it for a few minutes and plug it back in, it does actually give me a green light, and click, but then it goes back off after a few seconds and stays off. As for the "distortion" it is actually more like static. I can hear a scratching from the speakers, and see small areas of static near the top of the screen usually, and a few green/red pixels here and there.
      • badwr2002
        • Feb 2012
        Ordered a $30 small signal board from ebay, and it worked perfectly.
        • redbaron1007
          Onkyo HT-R510 turns on and then immediatly off
          by redbaron1007
          I picked up an Onkyo HT-R510 that when I plug it in and press the power button will turn on and then a couple of seconds later turn itself off. When it turns on you can hear the relay click and then immediately click again and shut the power to the system off. I spent about 5 hours today trying to troubleshoot it and I did make some progress that may not actually tell me anything. It's still not really working and I'm not quite sure where to go next.
          Here's everything I've done so far.
          The first thing I did was open it up and check for any burn marks exploded parts...
          11-14-2021, 09:55 PM
        • modtool
          Huawei Matebook D14 - NbB-WAH9Q - Shorted DrMOS MP86945A - DAH98NMB8B0
          by modtool
          Hi to all, this laptop came with no signs of life, no battery chargin and no start.
          I found that the main 19v rail was almost shorted, it measured around 7 Ohms , then searching better I found a shorted MP86945A DrMOS (between Drain and Source) that converts the 19 volts into the PCH core voltage...
          I was going to chuck the towel, but I had a new same DrMOS then decided to solder it in, then I connected the power jack and the system now powers almost on, all the voltages rise but the CPU core and VGFX core.
          Externally I only see that keyboard backlight lights up for 2 seconds,...
          09-29-2025, 08:05 AM
        • jean luc ferre
          laptop hp g72 b52sf screen problems
          by jean luc ferre
          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
          06-07-2025, 03:27 PM
        • vladyok96
          HP OMEN 15-ek1060ng (46H61EA), MB: DAOG3ETB8E0 Rev.E
          by vladyok96
          I couldn't find a topic for this laptop, so creating one.
          After a bios update (to the latest provided by HP on the product page, ver.F41), my HP OMEN 15-ek1060ng (46H61EA) wasn't turning on after a shut down. So after a reboot all was fine (not exactly, it has other problems, which I'm addressing now, probably with RAM, but at least it booted), but after a shutdown it won't turn on, only a CMOS reset would help until the next shutdown. I was trying to downgrade BIOS via AMI BIOS tool, but was getting error 46. So I decided to downgrade manually by flashing clean BIOS (ver.F39)...
          10-30-2025, 04:47 PM
        • Zparts01
          820-02841 Problems
          by Zparts01
          I have a 2023 14" MacBook Pro A2779, logic board 820-02841. I bought it off of eBay (probably my first mistake these days). The keyboard was destroyed and strangely enough many keys looked melted off. I found out was it was damaged by a liquid spill into the keyboard (looked like coffee) and maybe someone tried to dry it out with a heat gun and melted the keys, failing miserably. It was disclosed to me that the keyboard didn't work and that the MacBook would shut down right after clicking English (or any language) from setup and clicking to go to the next step. The power just goes off. If...
          06-10-2025, 08:44 AM
