Zenith Z50PG10 - Voltage Discrepancy 60V vs 5V ?!
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    #41
    Re: Zenith Z50PG10 - Voltage Discrepancy 60V vs 5V ?!
    Originally posted by electronicsurplus
    Has anyone ever seen a YSUS with ONLY the top being defective? I have tried several Upper Buffers and the same result. (With the upper removed I have bottom but, no top
    When Upper Buffer is installed there is no backlight nor video
    Any ideas?
    Plasmas Dont have 'Backlights'! Backlights are ONLY used on LCD Crap!
    Plasma screens use a completely Different Technology. Its Photo-Emissive not Photo Transmissive like LCD rubbish.
    Plasma have a Priming Glow derived by Y-SUS working with X/Z-SUS, visible in Darkened room.
    IF you've confirmed the buffers you've been using are good--Then highly likely the panel itself is short,--maybe cracked-- somewhere in the upper half.
    TELEFIX
    • electronicsurplus
      • 210
      Absolutely NO shorts checked each thououghly
      Absolutely NO shorts Tested Thoroughly
      That is the confusing part.
      I have seen a YSUS either bad or not. Never only 1/2
      I wonder if I am missing something?
      Originally posted by newtothis
      All buffers received free from shorts on check?
      I was wondering whether there could be a bad output or something only affecting the upper buffer?
      How to test a panel for short(s) ?
      I have tested both buffers and neither is shorted at all
      As far as testing using diode mode from ground to output pins using a zipper like fashion
      Is there another way to test these buffers ? EBR50039001
      Here is a pic
      Last edited by tom66; 04-28-2015, 08:14 AM. Reason: Keep the posts together, please
      This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
      Help keep these from the landfills
        Both upper and lower receive the same sustain output from the Y-sustain. It's not possible for a Y-sustain to drive only the top buffer badly. You could have a pinched ribbon cable.
        • electronicsurplus
          • 210
          So, there is only 1 output from the YSUS to both buffers Correct?
          Then I will check for a pinched ribbon or possible panel short. I think I will try to isolate the short by removing the IC Driver Chips one by one until the top turns on somewhat
          Thank you all for the input
          • legg
            LG 42PC3 buffer output doesn't follow YSUS
            by legg
            LG42PC3D -UD originally with green lamp but no display or audio.
            Owner says was working, then went 'pop'.
            All 5V caps bulging. replaced.
            All PSU output voltages within spec but -Vy is low on YSUS.
            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
            eventually shorts DG. Replaced all 3 - -Vy now OK.
            Y scan buffer test point does not follow YSUS output below -50V
            Note: This unit seems to expect YSUS output to park at -Vy in between
            drive signal pattern periods. A replacement drive signal board confirms this....
            11-18-2021, 11:49 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • PlasMatt
            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
            by PlasMatt
            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
            09-20-2025, 06:50 PM
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
